02-23-2023, 12:37 PM | #1 |
Rep 33
Short Circuit Fault 9CBB and A8A9
Ive had a soft code for a short circuit fault 9CBB the right high beam cornering light and gives error code A8A9. a friend recently tried to reset the counter but it won't go away. We followed this guide https://www.bimmerfest.com/threads/t...module.866044/
We reset the lamp fixture: 0x01 High Beam, Right or E92/3 Cornering Light The job said it was ok but when we go to check the codes, it's still there. Any idea what else we can try? Thanks in advance! Last edited by BabyHaulr; 02-23-2023 at 12:44 PM.. |
04-03-2023, 04:55 PM | #2 |
Rep 138
I just did this to reset a defective brake light. I used a youtube walkthrough using Tool32 that worked for me. An important part was slightly different models/years have different lamp numbers so you can't just assume the lamp. I ran the report for lamp numbers and then used Google Translate to figure out the correct lamp number to reset.
Used this and Google Translate: Last edited by askme; 04-06-2023 at 10:35 AM.. |
