02-24-2023, 11:22 PM | #1 |
Rep 429
Do Not do this to your key fob
So the car came with a very used key fob. I thought it was a good Idea to buy an empty key fob from Amazon and switch it over, Easy right? WRONG.
These keys come super glued together. I mean together like naturally occurring in earth. The idea was to swap out the chip from the old fob to the new one. I was very excited and though this was going to work. I tried to break the black plastic part but instead I ended up ruining it. Went to my local BMW parts place and ordered two new fobs and a blade. Cost me more than 900 bucks!! OUCH Guys this post is to show you my experience with this types of things. We all want to personalize and restore certain parts of our trucks to make it our own. Here are the pics..... |
02-25-2023, 07:52 AM | #2 |
Rep 5,015
Your local locksmith should be able to do this for about $200 each. Take a look around.
Sorry for your loss, but thank for poaching sow we know how to go about fixing this! |
02-25-2023, 08:03 AM | #3 |
Rep 477
I did this as my wifes OEM fob was missing a button. The tolerances are not the same on these after market ones. It was a challenge for sure but I was able to frankenstein her fob. One of the buttons is a little tight/stiff but works. She hardly ever uses the buttons so all good. It's doable but not a project for the faint of heart. Some micro screw drivers and files are a must.
02-25-2023, 10:12 AM | #4 |
Rep 108
I went with a key fob shell like this. Made it a bit bigger but tolerable. https://www.ebay.com/itm/114029584833
02-25-2023, 03:06 PM | #5 |
Rep 105
if your fob is messed up, just get something like this to make it look nicer:
https://www.amazon.com/gp/product/B07D3JWC72 |
02-25-2023, 05:22 PM | #6 |
Cattlecar
44
Rep 141
Are these keys ready to go once you take each one into car by rh side of steering column and push start button or did you have to get them programmed another way?
02-25-2023, 11:46 PM | #7 |
Rep 429
These "keys" are just plastic shells of what should be the keys. There is no need to program anything as you are taking your chip out of one shell and placing it into the other. That was not the case with me. The OEM key fobs are super glued together and doesn't not allow for an upgrade.
02-26-2023, 05:44 PM | #10 |
Rep 140
I actually just did this and had no issue. The secret is to look at the replacement t key and try to disassemble it the same peices.
The thing that sucked was that the oem key did not fit, so I had to go Take a picture of the actual key that unlocks the door and have it cut for me. That cost $13 or so. Local locksmiths wanted 90 To just cut the blank! One you get to the last part that is glued or melted together, I used an exacto knife to cut the seams u too I was able to pry with out damaging the board. The whole change out probably took 15 minutes. |
02-28-2023, 05:15 PM | #11 | |
Rep 1,532
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6 |
imr3n43.50 |
