03-27-2023, 10:13 AM | #1 |
Rep 1,311
I’d there a car-play system for my M3?
I’ve been off the forum for a long time and my M3 is in need of some work and upgrades.
I think, is the CCC system with iDrive and DVD maps. Map never works anymore and I think it’s the DVD finally has small scratches. The stereo/iDrive display will crash once in a while listening to music via my iPod. I’ve looked ad Bremmen and stumbled across the eonon system but seems those are not compatible. What are my options, if any, to upgrade my system and retain iDrive functions with the display head? RB Last edited by BimmerRob08; 03-27-2023 at 10:46 AM.. |
03-27-2023, 05:00 PM | #2 |
Rep 362
Drives: E53 X5, E83 X3, E93 M3
Just upgrade to a CIC and combox.
I did it...wasn't too hard...followed instructions...and bam! BT phone feature with details and sounds great! Perfect integration and relatively inexpensive parts all sourced. Oh...and my maps are now up to date with 2021.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
Ali-E90381.50 |
03-27-2023, 05:24 PM | #3 | |
Rep 1,311
As for what you mentioned, can I go with this system here? https://www.android-car-dvd.com/coll...33378244952200 How exactly did you upgrade to a CIC and combox? Is it a kit or did you have to purchase parts separately? cheers, RB |
03-27-2023, 05:36 PM | #4 |
Rep 362
Anyone that charges for a "kit" charges OUTRAGEOUS prices for what it's worth. I think I did mine for the CIC HU, screen, USB harness, COMBOX, KUFATEC harness....was like $359.
I do not particularly care for ANY of the "android" kits/mmi kits. I used something similar with my X5, and it was trash. Just crappy implementation with a lot of flare--but this is just my opinion....not to mention that the quality of OE is much better than any of the aftermarket junk. I would occasionally get these LIN errors and squirrelly functionality. Again...just my opinion from my own experience.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
03-27-2023, 09:13 PM | #5 | |
Rep 1,311
03-27-2023, 11:22 PM | #6 | |
Rep 362
In terms of CIC, I have no issues with mine and the "M" button on the steering wheel. I'm not sure if this is a feature or not. Upon startup, mine connects fine to BT and then immediately starts playing music after about 30 sec or so.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
03-28-2023, 12:43 AM | #7 |
Rep 117
If you decide to go for CarPlay, get the MR12V kit as it’s the only one that uses the most loop and therefore provides much better sound quality.
Personally I did do the CIC conversion and I think you should too, but decide first as the MR12V CarPlay kit varies depending on which system you have. |
03-28-2023, 07:36 AM | #8 |
Rep 935
Drives: E90 M3
I was in the same boat with the CCC. Converting to CIC will require coding if that’s a hurdle. It was for me cause I’m lazy. I ended up getting one of the CCC in play units and it’s alright. For what I’ve gained in CarPlay I’ve lost in sound quality as others have mentioned. It’s an even trade for now but eventually I can see myself going CIC if I have time.
03-28-2023, 07:17 PM | #9 | |
Rep 1,311
Well that's good your M button is working as it should. Perhaps in the video I was watching the guy messed up because hitting the M button would turn his system off. |
03-28-2023, 07:18 PM | #10 | |
Rep 1,311
Sounds like I'm going to have to learn about how to convert to the CIC and I'll research the MR12V. I have the premium sound and definitely love it and don't want to compromise it. |
03-28-2023, 10:38 PM | #11 | |
Rep 1,311
04-03-2023, 11:00 AM | #12 |
Rep 246
It shouldn't affect that. Just need to update the programing on the CD changer to recognize the mr12volt unit.
I just installed mr12volt on Saturday. Took almost 4 hours but I was fiddling around with stuff. Someone who has done it before could do it all in 2 hours no issue. I have a 2011 with CIC so my screen resolution is much better. It may be worth upgrading to CIC if you really care about that, but otherwise mr12volt makes a CCC version on the unit. Overall it's probably the best way to integrate carplay/AA into an iDrive car. If you don't have iDrive ("single hump") then the Dynavin is what I would do.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
04-07-2023, 11:00 PM | #13 | |
Rep 1,311
So since my early 2008 E92 M3 has the CCC system, I simply buy this CIC product https://www.mr12volt.com/products/p2...pr_seq=uniform and convert, that's it? |
04-08-2023, 11:33 AM | #14 |
Rep 117
You don’t have to upgrade to cic first. It does make the car much more modern feeling.
If you don’t care, you can go straight to MR12V ccc version. Sound quality will be the same but screen resolution not so wonderful. Coding to make it work is nothing to do with a remap and will not impact it at all. Last edited by Adam M; 04-10-2023 at 02:58 AM.. |
04-10-2023, 01:35 PM | #15 | ||
Rep 246
1. Upgrade CCC to CIC, then install mr12volt CIC (the one you linked). Do the full upgrade first and get it working, then do mr12volt if you go this route. 2. Keep CCC and install mr12volt CCC Up to you which route you go. After using it for a week I do like it, my only gripe is it's a UI designed for touchscreens so scrolling thru options on the wheel makes it a little tedious.
-Thumbie
04-10-2023, 02:02 PM | #16 |
Rep 362
The OP originally states wanting the maps to work and retain the iDrive with using some external media player.
This can all be done simply with the CIC retrofit with the latest maps (WITHOUT needing DVD) and BT/ipod connection. I did all of mine for a very reasonable price of $360ish. And what do you get with mr12volt? A glorified aliexpress android radio for over $400? Not worth it.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
05-19-2023, 12:41 AM | #17 | |
Rep 1,311
I found this post but it's a bit old so don't know if there is a new method/vesion for easier installation. https://www.m3post.com/forums/showthread.php?t=780402 |
05-20-2023, 12:19 AM | #18 | |
Rep 362
That post is a pretty good start. I'm a little unsure what the "emulator" is for exactly. It doesn't talk about the combox upgrade or upgrading the maps to the 2021 or later or anything...or talk about programming. I mean I can help assist with specific questions, but have no clue to your mechanical/electrical/programming prowess. Maybe there's better DIY guides on another post of a forum. Honestly...i'm NEVER a fan of this forum's "search" feature.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
05-20-2023, 12:25 AM | #19 | |
Rep 1,311
RB |
05-21-2023, 01:49 PM | #20 |
Rep 362
Sounds like a plan!
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
