04-26-2023, 08:13 AM | #1 |
Rep 1
Rear brake pads and rotor replacement cost
I live in the Dallas area. I have a 2015 X5 35i. A car repair place wants 580.00 to replace just the rear brakes. Is this a fair price??
Thanks Last edited by Go-Blue; 04-26-2023 at 08:33 AM.. |
04-26-2023, 09:29 AM | #2 |
Rep 7,554
Did you compare it to BMW Value Services offered by your local BMW dealerships?
If you're unfamiliar with this...BMW has been offering competitive service pricing for BMWs older than 60 months & out of warranty. You can check if any local BMW dealership's at the following link. Just enter your zip code and then select any a dealer and enter your model/model year. If you have more than one dealer, I recommend checking them all because they may offer different pricing and/or different services: https://bmwusaservice.com/valueservice Comparing your local BMW dealership's pricing to local Indy's pricing should give you an idea...especially if you look up the cost of the parts required to DIY. You'll see the cost of the labor vs just the parts.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-26-2023 at 09:41 AM.. |
04-26-2023, 09:40 AM | #3 | |
Rep 666
I'd say the price is fair, but I'm betting that quote is using OEM/aftermarket brake parts. Which you could DIY for easily half of that figure. Guessing the line items to get to $580: Labor: 1-2hrs book time @ $120-$150/hr Rotors: $75-$100/each Pads: $50-$100/set Brake Wear Sensor: $15-$30 Shop fees & supplies @10% of total |
04-26-2023, 10:38 AM | #4 |
Rep 157
Seems fair, maybe slightly high for aftermarket parts.
I went with Brembo rotors/brakes last time around, they were a bit cheaper. I had tried Zimmerman first, but they gave me horrible squealing. The Brembos have been good, but perhaps a bit dusty. The service specials @Qsilver7 mentions above are not that much more expensive than your indy quote, perhaps worth considering with OEM parts. |
04-26-2023, 11:28 AM | #5 | |
Rep 666
My friend complains to me about the brake squeal which had me wondering if it was the pads or rotor, or even the combo of both. |
04-26-2023, 11:43 AM | #6 | |
Rep 157
EDIT: Here's how bad it was with the brand new Zimmermans: https://streamable.com/n2be5y Last edited by Amsterdave; 04-26-2023 at 11:50 AM.. Reason: added video |
04-26-2023, 06:02 PM | #7 |
Rep 93
If you're handy (and have somewhere to do the work), I'd consider learning it yourself. Brakes are actually quite easy to do on most cars, including the F15. It's one of the biggest ripoffs or money makers for mechanics for so little work.
You can have the rotors turned (usually only once) by a shop or some of the O'Reily's auto parts have a brake lathe. They cost about $15-$18 per rotor. If you replace the rotors, it's even easier because you just simply remove the old ones, install the new pads and put it all back together. I can do my rear brakes in about 40 minutes with new rotors. |
04-27-2023, 12:20 AM | #8 |
Cattlecar
44
Rep 141
Brakes have many factors to consider. The manufacturer wants low noise, acceptable wear, and reasonable pedal pressure to stop vehicle with no power assist working to reuce pedal effort. Dust is low on the list or not on the list. Low noise and low dust are readily available but high pedal force w/o working assist is a low score. Rotors figure into this too as soft rotors give lower effort and better stops but rotor wear i greater and distorted rotors is a higher risk. Aluminum rotor hubs reduce unsprung weight for better suspension and steering response and cost more and many do not drive in a way to ever feel the dialed up handling benefit for those rotors. Tracking a vehicle makes for a whole nother level of choices.
04-27-2023, 01:25 AM | #9 |
Rep 5,015
Weird about the Zimmermans. I used them on all four corners with OE BMW pads and they never make a peep.
Never tried the OE knockoff pads on this car yet |
04-27-2023, 01:26 AM | #10 | |
Rep 243
04-27-2023, 12:22 PM | #11 |
Rep 1,497
I think OEM brake pads are the key to the no squeal. I got burnt once on my older E46 M3 going with aftermarket pads. Had them on for 2 weeks and that's all the squeal I could take. Installed new OEM pads and no squeal. I've learned my lesson.
04-27-2023, 12:54 PM | #12 | |
Rep 666
Data Point #2 - aftermarket stuff: I've had bad luck in the past too with aftermarket rotors on an E36 M3. Lots of runout and brake shake until I switch back to factory. BMW rotors, while expensive, give less headaches. |
04-27-2023, 02:05 PM | #13 | |
Rep 1,497
Clifton227.50 |
05-11-2023, 12:57 AM | #15 |
Rep 5,015
