05-25-2023, 04:13 PM | #1 |
Rep 112
Drives: 2015 m3
nbt to nbt evo id6 conversion
My car is a 2015 with nbt. I plan on buying the nbt evo headunit 4.1 with id6 and just using my same screen and I drive controller. I know I need to get it coded to my car but what else do I need for the new headunit to work. Maybe WiFi antenna ? If you have links of what I need please send also someone that can code the new headunit to my vin.
05-25-2023, 06:37 PM | #2 |
Rep 79
For coding, I would recommend kubax86. He recently coded a 4.1 head unit and 10.25" touch screen to work perfectly with my 2015 F80. He did it remotely after I installed all the hardware. As for other parts, I purchased the following:
You'll also need a laptop, network switch, and ethernet cable. kubax86 can fill in the remaining blanks. Good luck! |
05-30-2023, 06:35 PM | #3 | |
Rep 112
Drives: 2015 m3
05-30-2023, 07:30 PM | #4 |
Rep 79
