BMW X5 and X6 Forum 2014-Current
      05-29-2023, 04:56 PM   #1
terryz84
Drives: Evque => X5
N55 Bootmod3 flash failing at 1%
Now my car won't start, getting the The warnings on the iDrive say;
Drivetrain malfunction
Chassis stabilization
Tried unplug the battery for more 10mins, wouldn't fix the this... Still won't start 😔
      05-29-2023, 05:08 PM   #2
Cdeez2011
Cdeez2011's Avatar
Drives: 2016 F15 X5 35i
You'll need to flash it back to stock map. That will bring it back to normal. I did that cuz my dme is bench locked
      05-29-2023, 05:42 PM   #3
terryz84
Drives: Evque => X5
How would I flash it back to stock map? I getting the same failed at 1% when trying to flash stock map on bootmod 3.
      05-29-2023, 07:33 PM   #4
terryz84
Drives: Evque => X5
Any suggestions would be greatly appreciated. Thank you!
      05-29-2023, 08:37 PM   #5
beats
beats's Avatar
225
Drives: 2015 911 GTS
I would reach out to the bootmod guys. I found the support quite good with them.
      05-31-2023, 09:32 AM   #6
Cdeez2011
Cdeez2011's Avatar
BM3
There should be an option that says flash and re lock on the stock map. I tried the other options that didn't have the re lock and those failed for me.
      05-31-2023, 05:12 PM   #7
corduroy
Drives: '16 X5 xDrive40e (F15)
How are you flashing? Android/iOS/PC? How are you connecting? USB-C ethernet cable, ethernet cable, wifi?
I had the hardest time going back to stock with their new app a couple months ago. I think the update that was pushed today is supposed to help. I was using Android with a USB-C ethernet adapter. I spent about an hour trying to flash stock with it giving up every time until I finally got it to flash. I think the usb-c ethernet adapter wasn't being kept awake (kept going to sleep) and that would stop flashing - just a guess though. I just kept on retrying and keeping the phone on but not moving in case it was a faulty adapter.
If you can, try the PC way to flash.
      06-01-2023, 07:47 AM   #8
terryz84
Drives: Evque => X5
Thanks guys!
Back for forth 2-3days with bootmod guys. Finally got it fixed. It was actually pretty easy to fix it by just using bootmod3 to restore back to stock tune, re lock DME.
My DME was locked by dealership from a software update. Now I need to find a place to get my DME unlock first before I can use bootmod3 again. Any place recommended in NY?
      06-01-2023, 10:10 AM   #9
ErikV55
ErikV55's Avatar
18
Drives: 2017 X5 xDrive35i M Sport
Thanks guys!
Call well regarded bmw tuner shops in your area. I bet most of them can do it. Most places don't advertise they do it.
xbimmers
