05-31-2023, 11:15 PM | #1 |
caffeine fiend
44
Rep 46
Future owner - questions
Hey all,
In the next coming months I am planning on hopefully picking up either an M3 or M4 and was curious about a few things. I am new to BMW and this will also be my first German car so I'd like to get some expectations and insight. All of my cars have been Japanese, a Subaru WRX, a Honda Civic Type R, Lexus GS350, Mitsubishi Lancer. Except currently I am driving a C6 Corvette that I am selling this weekend. Personally I would like to get the M3 over the M4 but with popularity and supply I am actually finding the M4 to be a little cheaper and more readily available, i don't think in the end i would be displeased if I had to get the M4, but coming from the Corvette I learned I really hate having the longer door, and just on the Corvette it is a pain to get in and out of. Is there anything I need to look for in these cars? |
06-01-2023, 07:46 AM | #2 |
Rep 557
I like the lines of the 4 door better...but I am biased. Also more fun when you are passing guys on the track and your car seats are still buckled in the back.
06-01-2023, 09:30 AM | #3 |
Rep 6,126
Best of luck with your search. Do you already have one picked out?
The M3 is more expensive than M4, as you noted. It's twofold: (1) more M4s were made than M3 (more years of production, plus I think more were M4 per year); and (2) having four doors makes the car more usable to more people. I had M4 before and M3 now. They (obviously) drive very similarly, but there are some subtle differences in the way it feels. If you can, I would recommend a PPI just to make sure everything is good to go with the car before you buy. Obviously not that common, but there are some cars out there with major issues that the seller is trying to hide.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
1heckinboi44.00 |
06-01-2023, 10:08 AM | #4 | |
Commander-In-Chief
2196
Rep 8,947
06-01-2023, 06:16 PM | #5 | |
Rep 54
When I went from the convertible e46 m3 to the e92, I remember being really excited to finally have 4 doors... but given how rarely I had 4 passengers, it just became the lazy man's trunk. I'm not sure i would take the 2 door m4 coupe tho... either 4 doors m3 or a convertible M4, the 2 door coupe just doesn't do as good as the other two. Agree you should go for a test drive, though I doubt you'll notice real differences between the m3 and coupe m4 not related to weight. The weight is especially noticeable with the convertible, but can be managed mostly with tighter suspension Things that have failed in my actual experience:
You should do a visual on the charge air cooler when you buy the car, it's the reservoir closest to the windshield center. If it's empty, it should be replaced but the car will generally not throw codes for this and the car will drive normally, and then it won't. You'll probably also hear: Crank hub, seems to be a thing for aftermarket boosted cars. And the rest has just been regular, albeit expensive, maintenance (suspension is kind of insane if you get EDC). While the repairs above have been more expensive than i would like, it's a shorter list than the e9x (and wayyyyyyyyyyyy....yyyyyyy shorter than the e46 that liked to rip itself apart) |
1heckinboi44.00 |
06-02-2023, 12:16 AM | #6 | |||
caffeine fiend
44
Rep 46
As far as the doors go, I just hated coming back to the vette and finding someone parked a bit too close to me and I would need to squeeze myself in. I have a pretty spacious garage and I still feel like I need to swing the door out fully to even comfortably get out, I'm not an old guy with back issues either aha |
06-02-2023, 06:35 AM | #7 |
Rep 138
i also came over from a civic type r (fk8)
i loved that car but as someone who rarely drives with other people in the car, i would have loved a two door variant with a hatch so for me, the m4 was my preference i just prefer the look of the coupe i guess. the coupe and the sedan are roughly the same size but when i’m washing the car it feels a lot easier with the coupe somehow 😂 |
06-02-2023, 07:38 AM | #8 |
Rep 628
Just get a good PPI. I bought my 2016 with 20k miles on it. Car was tracked but well maintained so it didn’t bother me. Only failure was idrive and fixed under warranty. Stage 1 BM3 when I got it and now has 72k miles.
Only other work is usual maintenance, namely oil changes, spark plugs, filters, brake fluid changes and brakes. Additionally at 40k I did engine coolant and charge air coolant. 50k I did DCT fluid/filter, and diff fluid. Recently did the serpentine belt, water pump belt, tensioner and pulleys. Trick is to stay on top of maintenance and do thorough inspections. At every oil change or after every track day, take a close look for fluid leaks, loose/worn suspensions bits and bushings. |
06-02-2023, 01:50 PM | #9 | |
Rep 54
But if you get a convertible you can fantasize about never opening the door to get in or out... regardless of how close people park #logic Joking aside, would be curious to hear your impressions after test drives |
1heckinboi44.00 |
07-19-2023, 03:49 AM | #10 |
caffeine fiend
44
Rep 46
Managed to get an M4 a lot sooner than expected, one had came up with the specs I wanted except in Alpine White. Looking at it though it really suits the car and the carbon fiber sits perfect with it
Car-Addicted7225.50 TractionControlDelete4601.00 Deano123111.00 santiwan180.00 Brad_T36.00 NickyC17648.00 spidy512502.00 |
07-19-2023, 05:05 PM | #11 |
Rep 557
1heckinboi44.00 |
07-19-2023, 08:34 PM | #12 |
Rep 47
Congrats on the M4. Beautiful.
1heckinboi44.00 |
07-19-2023, 08:46 PM | #13 |
Rep 536
I don’t have a spreadsheet handy with my maintenance costs so far, but I intend to keep this car as long as possible.
Every 4-5k miles I change the oil since I don’t drive my car hard or heavily (maybe 150 miles a week). I’ll probably will decrease that interval to 3k Annually I just change out plugs just because. 2018 had the IKONS. Full screenCarPlay can be coded in down the line, so don’t let that deter you. I have a sedan just cause I like the wider flares hips on the sedan (M3/4 can fit the same wheels, I just like the appearance of the flares hips) It may be a German car, but same rules still apply: get a PPI and/or ask for complete service records. I’m not mechanical, but surprisingly it isn’t much harder to DIY basic maintenance on this car. I found that all shrouds and whatnot come off and reinstall much easier Compared to my previous cars (G35, WRX) If you’re a DIY guy as well, get your maintenance products through FCP Euro and take advantage of their lifetime replacements. I also learned I thoroughly *LOVE* the DCT. I’ve never driven a DCT or SMG before, let alone an M3. This car was my foray into both and I have not been disappointed. |
1heckinboi44.00 |
07-19-2023, 10:27 PM | #14 |
Rep 10,722
Drives: M4 CS. Former G82, x2 F82, F80
I've had three F82 cars now along with an F80. I really liked the F80 hips, but that was it. For me the F82 is a slightly better looking car all around (especially from the rear which is FAR superior to the F80 rear imho), and it's MUCH easier to get into if you're a big guy like me. I was constantly smashing into the door frame when entering/exiting the F80. Yes the doors are much larger on the M4 of course, so you need to be more careful upon exit when parking close to cars (especially if you own a CS, better learn to hold on to those door straps!).
I also noticed the wind noise with the windows down is much worse in the F80, you get a buffeting of wind at speed in the F80 unlike in the F82. It's very obvious when you've owned both cars, and if you like windows down driving it sucks quite honestly in the F80, especially at highway speeds. |
1heckinboi44.00 |
07-19-2023, 11:07 PM | #15 |
Rep 696
Drives: 2015 f80 M3
Congrats!
Even though the F80 is a faster and better looking... especially Mineral Wiess... its the hips... Seriously, great looking ride. My Dad had an 18 Comp and it was an awesome ride. It was for the most part a twin of yours, but carbon structuure interior. Have fun! josh |
1heckinboi44.00 |
07-19-2023, 11:09 PM | #16 |
Rep 6
things in earlier models:
battery health - sounds silly but they’re Lithium and £££ valvetronic and eccentric shaft - clicking noise on startup/unlock or lock/poweroff. water in the doors on coupes from blocked drain plugs (check rear windows drop at same speed for regulator health - check when you press window down or up once its automatic meaning limit switches are working, and check for no water under the boot floor on the left near the amplifier. |
1heckinboi44.00 |
07-20-2023, 02:01 AM | #17 |
Rep 193
Congrats, Im a fairly new Alipne/F82/CS owner as well. Seems everyone likes the "hips" on the F80s better I personally thins the coupes look better overall.
Nicky mentioned the door straps, not an issue for you, but took me about 3 times to get use to it. the doors are a little on the long side. Enjoy the ride and be ready for the goofballs that want to race you evertime you stop at a light. |
1heckinboi44.00 NickyC17648.00 |
