Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      06-06-2023, 08:58 PM   #1
lastround360
Drives: BMW M4
Angry SSR Intake causing lean AFR
Installed an SSR Intake about 3-4k miles ago and since then have had p0171/p0174 come on occasionally. I smoked the intake and there are no leaks. I notice the fuel trim only goes high at higher RPMs, at idle everything is fine. Have read this is consistent with air metering issues and that this is a common problem with aftermarket s55 intakes due to the diameter of the piping and/or the placement of the MAF. Given all this I have two questions.
1) Is this something I can tune out with BM3?
2) Could I have sustained any engine damage these past 4k miles from running lean? I've heard a lean AFR can cause overheating of internals. Not seeing any other codes aside from the lean ones and no knocking, rough idle, or anything like that.
2017 M4 20k miles
f80post
