06-27-2023, 02:02 PM | #1 |
Rep 10
Bimmerlink wheel speed sensor error list
Hey guys,
I had a front/right wheel speed sensor error along with several others when running a scan with Bimmerlink. I replaced the front right wheel speed sensor but I'm seeing 2 other sensors now on this list and the ABS light on my dashboard is on as well. It seemed like a pretty straight forward procedure to replace the front right sensor, but I still see the error on this list. Does it take a little driving for it go away? After seeing this error list generated I was just going to go ahead and replace the other 3 wheel speed sensors to see if that helped. What do you guys think based on this output? |
06-28-2023, 01:53 AM | #2 |
Rep 1,117
You need a real code reader. They do not all fail at the same time. A good code reader tells you which one failed. If you purchased OEM speed sensors, you wasted more than the cost of a real BMW code reader
06-28-2023, 11:22 AM | #3 | |
6 Cylinders 3 Ways
369
Rep 460
Replacing all of the wheel speed sensors is one way to solve it though. |
06-28-2023, 11:57 AM | #4 | |
Rep 10
