06-28-2023, 05:49 AM | #1 |
TrizzlemyniZzzlE3
71
Rep 585
Check engine light pulling out of driveway rough idle engine cold
Have a check engine light that goes away when cleared and warmed up , car has 70k miles . Will pull codes one of these days thinking it might be plugs as the car is tuned and they have over 10k miles on them , coil packs haven’t been replaced yet . Any information or somebody had this problem in this past ? Car is running fine it seems
06-30-2023, 04:31 AM | #3 | |
TrizzlemyniZzzlE3
71
Rep 585
Pulled the codes this morning . Any help is appreciated my old wrenching buddy says coil pack n plugs a great place to start then injectors DME active codes - 118002 - Mixture control: Fuel-air mixture too rich. 118102 - Mixture control 2: Fuel-air mixture too rich. 138104 - Exhaust flap, activation: Line disconnection. 138A04 - Exhaust flap 2, activation: Line disconnection. - DME shadow (inactive) codes - 118501 - Mixture control 2: Fuel-air mixture too lean, large deviation. 11 CF30 - Mixture control: Multiple fault. 11CF31 - Mixture control 2: Multiple fault. 138102 - Exhaust flap, activation: Short circuit to ground. 138A02 - Exhaust flap 2, activation: Short circuit Last edited by Ryguy29; 07-04-2023 at 12:40 PM.. |
06-30-2023, 10:19 AM | #4 |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
Double Check your Charge Pipes to the TMIC. Might of cracked or came loose.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
07-02-2023, 07:49 AM | #5 | |
TrizzlemyniZzzlE3
71
Rep 585
One charge pipe indeed seems loose , thank you so much for the response idk why I never thought to pop the hood and take a look. Local shop was insisting bringing in before ordering parts now I know why |
07-03-2023, 07:24 PM | #6 |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
That's what I'm here for... LOL just kidding.
N1rve
07-04-2023, 12:36 PM | #7 |
TrizzlemyniZzzlE3
71
Rep 585
Turns out the bolts won’t tighten up enough to make pipes seat nice and tight ? Their evolution charge pipes . Any body have this issue ? Bolt is deff at its limit and has 1/8th to 1/4 of play , almost seems like washer isn’t flat anymore but it’s part of the charge pipe..: might hafta throw the stocks on to see if this is the problem … Tried taking a video having trouble uploading /if you would like to see one please text if you don’t mind I really would like to figure this out Ryan 516-642-2866 Last edited by Ryguy29; 07-04-2023 at 12:41 PM.. |
07-05-2023, 07:28 AM | #8 |
TrizzlemyniZzzlE3
71
Rep 585
after messing around a little got the stock to fit nice and snug and was determined to get er back on , noticed a bit of oil moving the oring clean that and seems to have seated properly now / this still has some play but not as bad as it was when it gave me a code , was thinking to order a set of mishimoto soon...
07-05-2023, 01:36 PM | #9 | |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
N1rve
