07-05-2023, 06:11 PM | #1 |
Rep 183
Hello, I am currently in the process of installing an interchiller kit into my f80, along with some more goodies. I currently have a turner vent gauge to my right for my boost pressure, and am installing the p3 vent gauge to my left. I have a custom made interchiller gauge that will read the active interchiller temp. I want to get mounted in a good area that wouldn’t require too much hassle to have it mounted or set up. Anyone use a mount that they can recommend or a location especially they like to use? I’ve seen the typical a pillar mounts but I also saw one which goes in the dead space of the screen and dash. Just want to see what everyone else is using before I pull the trigger on what I see best or what my shop recommends. Thank you!!!
07-05-2023, 06:36 PM | #2 |
Rep 1,371
Sounds like you have little faith in your tuner. LOL. Honestly though, you've used up all real estate there. Not sure anything exists for your needs.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
kamilbaran138.00 |
07-05-2023, 06:56 PM | #3 |
Rep 502
Can you display the data to iOS or android and use your phone?
kamilbaran138.00 |
07-05-2023, 06:58 PM | #4 |
Rep 183
I just want to get it before hand. I am going to ask them if I don’t see one I like though when I go to drop off the gauge and fuel injectors fridays
07-05-2023, 07:00 PM | #5 |
Rep 183
07-05-2023, 07:25 PM | #6 |
Rep 5,187
Why not do the other vent?
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
kamilbaran138.00 |
07-05-2023, 07:27 PM | #7 |
Rep 183
07-05-2023, 07:31 PM | #8 |
Rep 5,187
The reason I asked is because vent pods stay cool, where dash-top and pillar pods can overheat from the sun.
kamilbaran138.00 |
07-05-2023, 07:35 PM | #9 |
Rep 183
I generally did not take that aspect into consideration, thanks for throwing that out there. An a pillar mount wouldn’t be the worst in terms of sun exposure but would be more of an eyesore to look at. I could put the boost gauge as the further away vent and have the interchiller gauge the closer one for better monitoring.
TopJimmy5507.50 |
07-11-2023, 04:25 PM | #10 |
Rep 183
ended up going with these ones, incase anyone ever is interested and needs a gauge pod:https://podwurx.com/f30-f80-cluster%2B-pod
