New 2009 2010 BMW Z4 - ZPOST
      07-23-2023, 09:22 AM   #1
B21
B21's Avatar
167
Drives: E89 Atacama Yellow 35is
A few mods you could do?
My wife often asks me "what are you doing to that car now?" or words to that effect....also a few people have asked me "what mods have you done to your Zed?"
Today was a long wet and windy day..so I thought I'd try and remember some of the things that I've done to this "Yellow Peril"
I'm sure I've forgotten a few..maybe an inspiration for you?
1 Zito 935s 235/40 18 265/35 18 Michelin PS4S
2 Front HALO angel eyes LED upgrade
3 Remove silver slats from lower grills
4 Reverse colours on valance and rear diffuser
5 Gloss black Kidney Grills
6 Inlet port walnut blast
7 Mahle air filter
8 Dyno check 347 BHP 505Nm
9 2022 Map upgrade
10 Bluetooth s/w upgrade
11 MHD V9 stage 1+ 390 bhp 560 nm
12 xHP stage 1.2
13 NGK coils
14 NGK 1 stage colder plugs
15 Uprated oil thermostat
16 Redline ester based engine oil and Mahle filter
17 6 pot Brembo BBK front grooved /drilled
18 Uprated anti roll bars front and rear
19 Replacement parking brake motor
20 Engine bay strut tower brace
21 Zimmerman drilled / vented rear discs
22 Colour matched calipers Phoenix Gold
23 Catless down pipes
24 437M alloys with Michelin PS4s
25 Limited Slip Diff
26 MHD V10 stage 2+ 408 BHP 655Nm
27 xHP stage 1.3
28 Uprated HID bulbs
29 Revo boot rack
30 DCT aluminium deep sump
31 DCT oil and filter changes
32 Aluminium oil filter cap
33 Uprated suspension
34 Removal Adaptive ECU plus coding
35 Monoball bearing for front suspension arms
36 Evo 1 Intercooler
37 Z4 and 35is badges deleted
38 M3 E90 RTAB upgrade
39 Gloss black roll over hoops
40 437Ms refurbished in gloss black
41 E90 M3 front Suspension arms
42 Colour matched rear carbon fibre boot spoiler
43 Centre speaker upgrade
44 Door card speaker upgrade and door tweeter
45 Rear shoulder speaker upgrade
46 Rear centre speaker upgrade
47 Rear brake lights LED upgrade
48 Rear reversing lights LED upgrade
49 Pierburg alloy water pump + Mahle Thermostat
50 LCI side repeaters in gloss back
51 Retrimmed and flat bottom steering wheel
52 Later flappy paddles one sided action
53 5mm front wheel spacers
54 Arc 8 19" 8.5j 35 and 9.5J 33
55 Michelin PS4s fitted to Apex arc 8 in satin black
56 Arc 8 refinished in gloss black
57 245/35 19 275/30 19 Sports Contact 7
58 Meyle HD toe rods
59 Index 12 injectors
60 Stage 2+ DME re-map
61 Stage 2 TCU re-map
62 Stage 1 colder plugs
63 B58 Ignition coil kit
64 Uprated steering tie rods
65 Later all metal water pump
66 Adjustable toe and camber plates
67 Adjustable rear camber arms
68 Alignment done
69 New rear boot struts fitted
70 Garmin 57 and Mini 2 dash cams fitted
71 Fox centre and rear exhaust system
72 TTE 500 Hybrid Turbo Upgrade
73 Uprated turbo outflow pipes
74 Uprated turbo inlet pipes
75 Uprated charge pipe
76 Uprated 450 lph LPFP
77 Wagner EVO 3 FMIC
78 Forge diverter valves
79 Uprated GUIBO
80 Uprated centre shaft bearing
81 Tuning for new hybrids
82 Pipercoss panel filter
83 Dyno test day 502 BHP 683Nm
84 Footwell woofer upgrade
85 New boost controller solenoids
86 Carplay adapter
87 Carbon fibre wrapped interior trim pieces
88 Retrimmed gear gaiter
89 Replaced snap in tray with general tray
90 New set of 437Ms
91 437m refurbished and finished in graphite grey
92 235/35 275/30 SC7s fitted to 437m
93 Brembo HP front pads
94 Rear adjustable toe in plates
95 Uprated RTAB and rear linkage bushes
96 New aligment less rear camber better toe
97 LED lights for map reading, boot, puddles
98 New G29 Z4 and M50i badges
99 Refitted turbo oulet pipe silicon hose + heat shield
100 Mr.5 Inlet modification
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0
Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886
      07-23-2023, 06:07 PM   #2
MRCW
Drives: Z4 35i X1 35i
Adding a dash cam. Where did you pull your power from?
      07-24-2023, 03:48 AM   #3
B21
B21's Avatar
167
For other reasons…upcoming audio controller for DSP/amp so needed to change the ash tray from the smokers package…so I took the 12v power socket out of the ash tray and plugged a two port usb charger hub into it and hid it under the centre trim.
Fed the cables round to the two cameras.
Disadvantage, if it is, is that it on,y works when the ignition is enabled.
      07-24-2023, 10:10 AM   #4
B21
B21's Avatar
167
      07-25-2023, 12:15 PM   #5
MRCW
Thanks. I already pulled power from the center console power other to add USBs that I installed behind the radio v for cell prone charger. I thought perhaps you were able to find some power in the OH console. I'm only installing front dash cam for now so I'll probably tap the same 12v power and run up the A pillar. Just using ignition power for now since I just want can while driving and not while parked.
Thanks
      07-25-2023, 12:17 PM   #6
B21
B21's Avatar
167
Thanks
That’s the only ‘easy’ power supply..AFAIK..after that it’s either spur off an existing powe line or go to the fuse box from hell underneath the glove box (in the UK) and use one of the spares…
zpost
