07-28-2023, 10:38 AM | #1 |
Rep 35
TPMS question
Hey guys. Question. I had two speed sensors go out on a 2011 M3 E93. My dash looked like a Christmas tree. I live in the Florida Keys so there is only one guy that fixes them within 60 miles. So suffice to say, I knew I was going to get screwed. I did, to the tune of 1163 to replace the two sensors. Well, when this happened, I also got a TPMS error where it won't reset. The mechanic told me this happens when the ABS turns itself off because of the speed sensors. He said the TPMS module is working because there is a fault code that ALL TPMS sensors are out. He said try driving it and reset it a couple of times and that sometimes works but if not all 4 sensors would have to be replaced. Is that normal for all 4 sensors to go out at the same time ?
2011 E93 M3 6 SP, AFE Intake, BimmerWorld Race Exhaust, Alpine Tunes Stage 2 Bavaudio speakers, Matchup 8 Subs, Match UP7 BMW Amp, Kicker Solobaric custom box, Digital Designs Amp. Liqui Moly oils. Painted calipers, carbon fiber trims throughout, blacked out chrome.
07-28-2023, 12:31 PM | #2 |
Rep 21
I cant answer your question about all 4 sensors going out at once, but I can tell you that last year on a road trip home to Key Largo, both my front speed sensors went bad. I bought a scanner to find the issue, bought two $50 sensors, and installed them in my driveway. I think the scanner was about $300. This week on a road trip home to Key Largo, I had another ABS issue. I am assuming it is probably the rear speed sensors, but I have yet to run a scan to diagnose the issue.
Its hard to believe that someone charged you $1163 to replace the two sensors. Its probably a half hour to run a scan/diagnose, and a half hour each to replace the sensor. And then another half hour to clear the codes and re-run the scan. Please share who you used so I can avoid that guy. Dave |
spammysammich1606.00 DrFerry6731.50 |
07-28-2023, 12:46 PM | #3 |
Rep 1,128
Batteries in tpms don’t last more than 7 years in my experience. It’s possible for them to go out around the same time.
07-28-2023, 03:43 PM | #4 | |
Rep 35
Yes avoid at all cost. 200 for diagnosis which does not apply to the fix. 1.25 hours per sensor. The only reasonable cost was the oil change which was $ 300.
07-28-2023, 03:44 PM | #5 |
Rep 35
Yea that's what he said but man everything at once, speed sensors and that.. Just weird.
07-28-2023, 03:46 PM | #6 |
Rep 1,128
It’s a 12 year old car in Florida heat. Buckle up, you’re in for a treat if you hate money.
DrFerry6731.50 CamasM3e933222.50 |
07-28-2023, 04:15 PM | #7 |
Rep 21
There is a german car mechanic in Key Largo, European Motorwerk Autohaus.
I touched base with him last year about an oil change. I really just wanted to meet him and feel him out for future service. He told me I would need to leave the car overnight. Seriously? overnight for an oil change? I ordered some oil and a filter and did it myself. He has good reviews so perhaps its an option if I really don't want to do something myself. I really don't trust anyone to work on my car, but one day I will need someone I can trust. |
DrFerry6731.50 |
07-28-2023, 07:42 PM | #9 | |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
derbo3611.50 |
07-28-2023, 08:04 PM | #10 | |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
Transponder: https://www.fcpeuro.com/products/bmw...771042#fitment TPMS sensors (there are a few different types note the numbers on your old ones). https://www.apexraceparts.com/store/...ms-sensor.html Some other useful information here: https://www.m3post.com/forums/showthread.php?t=327609
07-28-2023, 09:46 PM | #11 |
Lord Scrip
1823
Rep 3,018
Drives: 2011 M3 Coupe
So I would recommend replacing all (4) TPMS sensors. So in your case you need two more. If you can’t reset the system still……Replace the module itself. As I recall it’s behind the rear passenger tire. Remove the silver air panel at the passenger corner and look up. It looks like an early 2000’s usb Wi-Fi device (pic attached). Also most capable tire shops have TPMS equipment. They can at least see if a wheel TPMS is broadcasting at all. The batteries die or road hazzards claim them.
DrFerry6731.50 |
07-28-2023, 11:56 PM | #12 |
Rep 258
At the same time, the 4 sensors are not working, it should be the TPMS signal receiver, the TPMS code of the 2011 BMW m3: HUF RDE012. The charge level of each TPMS can be checked using MaxiTPMS.
Four HUF-TPMS were replaced four years ago. 3 months ago, the screen said there was a problem with the TPMS. Checked the tire pressure, no problem. Check the TPMS of each tire with MaxiTPMS. Passenger side rear tire TPMS not working (no power). Know its code: HUF RDE012, for sale on Ebay Got a used replacement, replaced it, drove it and reset it. Last edited by jun_e92; 07-29-2023 at 12:32 AM.. |
07-29-2023, 12:56 AM | #13 | |
Lord Scrip
1823
Rep 3,018
