      08-04-2023, 09:45 AM   #1
M2 SoCal
M2 SoCal's Avatar
1541
Drives: 2024 M2 (G87)
Decoding for no-dazzle hgh bm?
Anyone know what this option is? It’s on my M2 order and not quite sure what that means.
      08-04-2023, 10:55 AM   #2
DomMuc
DomMuc's Avatar
Germany
835
https://g87.bimmerpost.com/forums/sh...14&postcount=4
its decoded cause in some states it´s not legal... you can activate no dazzle Highbeam with Bimmercode
      08-04-2023, 11:04 AM   #3
1stM
1stM's Avatar
524
Drives: '24 M2
This guy coded on his G80.
      08-10-2023, 09:52 PM   #4
cmgbk75
cmgbk75's Avatar
Drives: G87, G26, E46, Mk6 5K
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
How Anti-Dazzle looks in fog.
      08-10-2023, 09:58 PM   #5
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
Are those the high beams on?
Come on Canada! Yes, of course.
      08-11-2023, 01:55 PM   #6
Chet for short
Drives: TR G87 M2
Bimmercode for no-dazzle
https://g87.bimmerpost.com/forums/sh...6#post30369922
Vid shows how to code for no-dazzle. Also goes through all other bimmercode settings.
      08-14-2023, 09:21 AM   #7
GregW / Oregon
Commander-In-Chief
2608
Bimmercode
That is a different car though. I mean for the G87 it can’t be done.
From Bimmercode:
"Hi,
thanks for getting back to us - we are working on compatibility for the G87 but cannot promise a timeline yet.
Kind regards / Schöne Grüße
Sven Straubinger - Lead Developer
SG Software GmbH & Co. KG
Linsenäcker 18/1, 72379 Hechingen
Amtsgericht Stuttgart HRA 735678, Sitz: Hechingen
Persönlich haftende Gesellschafterin: SG Software Verwaltungs-GmbH
Amtsgericht Stuttgart HRB 769559, Sitz: Hechingen
Geschäftsführer: Stephan Gauch"
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      08-15-2023, 07:26 PM   #8
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
It’ll work for our car.
Side note, I drove about 60 miles late last night with cars sometimes front and oncoming cars and the Auto High Beams stayed on the entire time. It’s really cool watching the beam dance around the cars.
      08-15-2023, 07:39 PM   #9
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
So you coded yours? Can you share screenshots of the advanced options you changed?
Not this guy but he follows the same coding and it definitely works. It’s not complicated and takes less than 10 minutes.
      08-15-2023, 07:49 PM   #10
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
You’ll need two devices to do it. One with the instructions or screenshots (snap them from the video is probably the quickest. He posts the code. Example attached) and one connected to Bimmercode.
      08-15-2023, 07:56 PM   #11
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
I get it, but that’s a different car. I’m asking if you coded or if you can share your codes so I can compare.
And I’m telling you it will work in our car. Just log in as a G20 in Bimmercode.
      08-15-2023, 08:07 PM   #12
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
Ok I’ll try that then. I was just skeptic because Bimmercode says they don’t support it…
I hear you but they’ve said that about all the coding we’ve done so far. I promise you it’ll work. Just go slow. You have to use Expert mode.
      08-17-2023, 06:01 PM   #13
GregW / Oregon
Commander-In-Chief
2608
You log in as G20 instead of G82, or does it matter?
      08-17-2023, 07:24 PM   #14
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
I’ve used both G20 and G80 searching for more functionality, same results.
      08-17-2023, 08:26 PM   #15
GregW / Oregon
Commander-In-Chief
2608
Bimmercode
So used Bimercode for the first time today. Pretty easy, but limited in things it can do. Biggest for me is getting rid of the legalese notice that pops up EVERY time you start the car, that you either have to click on OK or wait for it to go away. The key is linked to your profile, so if you've agreed to it once, why does BMW insist on annoying you for the life of your car (typically one model cycle, 7 years for me)?! That is so stupid. My Mercedes doesn't do that.
And I changed the one touch turn signal to 5 flashes, and got rid of the seat belt warning (always wear mine w/o thinking). Tomorrow I'll do the anti-dazzle coding.
      08-17-2023, 09:22 PM   #16
sl0m0
Drives: Sedan
Are you selecting g20 or g80?
      08-18-2023, 07:30 PM   #17
apez
Drives: BMW G87 M2, F25 X3
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
Two questions... Does the MT have ASS, and can it be coded out?
      08-18-2023, 07:39 PM   #18
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
Yes, but you don’t need to code it out. It’s default is off.
      08-18-2023, 07:40 PM   #19
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
You can use either. End result is the same.
      08-19-2023, 07:47 AM   #20
cmgbk75
cmgbk75's Avatar
2023 M2  [8.82]
2022 i4 40  [8.43]
2001 325Cic  [6.67]
You were right, of course. It does work. Yay!
For those who don't want to watch the video, or need the notes, all you have to do is:
Open Bimmercode
Choose 3 Series/M3
- Go into the BDC Module
- Choose Expert Mode
- Find the following options and change them to these settings:
LA1
C_BLC_PRE_ENA | 1
LUT_FLC_FORWARDLIGHTING_Y | AFS
LA2
C_AFS_ECO_LEVEL_3_ENA | 01
C_AFS_ENA | 01
LA3
LUT_AFS_CODRV_HOR | standard/init
LUT_AFS_DRV_HOR | F040_G005_AHL...
C_CLC_CURV_V2 | 23
C_CLC_CURV_V3 | 28
C_CLC_EXT_ENA | 01
C_HBA_DIM_ENA | 01
C_HBA_GFHBA_ENA_V_HI | 3C
C_HBA_GFHB_ENA | 01
- Hit "Code"
- Enjoy!
Glad you got it! Beating a dead horse, but it’s such a great feature and with it being legal now, I have no idea why they still decode it.
      08-19-2023, 07:51 AM   #21
apez
2024 BMW M2  [8.10]
2015 BMW X3  [7.25]
I can't tell you how relieving that is. I hate that "feature" on my G42.
      09-01-2023, 05:56 AM   #22
Chris13002
Drives: 2023 BMW M2
Thanks for the help and making this easy M2siast
I also coded this and confirmed that it works through Bimmercode. Purchased OBDLink CX $80 on Amazon with same day delivery, and purchased the Bimmercode app for $50 on Android ($40 on Apple Store). Totally worth the money seeing the features you get with coding...
-Adjusted right passenger mirror tilt when in reverse to 70%
-Disable warnings when starting the car
-Bowers and Wilkins sound profile
-Thinking of disabling ASD (Active Sound Design = fake engine noises)
The "No-Dazzle" feature is my favorite and really wakes the car up at night. I drove through some dark empty roads and it lit everything up. Then when I got to a highway with some cars, just seeing the headlights constantly adjusting and moving around are amazing. No one got high-beamed, and it even adjusted it for a car on a perpendicular overpass.
Here is another video of what is does (not the same car but works exactly like this)...
