08-22-2023, 04:53 PM | #1 |
Rep 2,072
why does motiv tell you to not leave fluid in the tank?
so i have probably a half a bottle's worth of castrol srf sitting in the power bleeder tank from maybe 5 months ago. is the concern just moisture absorption, or that it's going to leach something out of the tank itself? it was tightened so i don't see it absorbing more moisture than if it were in the car for that period of time.
would prefer to not waste that much $$ fluid, but will if it's ill-advised...
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
08-22-2023, 05:08 PM | #2 |
1954
Rep 1,913
Drives: E92 M3
If the cap is tightened, it's still not sealed. It would be even better to place it back into the original fluid container and seal that.
FCP Euro has a video on it and state to recycle any fluid still in the bleeder (5 minutes, 16 seconds).
spammysammich1606.00 |
08-22-2023, 06:04 PM | #4 |
Rep 1,128
Have you tried running some denatured alcohol through and air drying before you stow it away? I’ve had good results with that.
Erickuokwa489.00 |
08-22-2023, 06:12 PM | #5 |
Rep 2,072
thanks all!
