08-24-2023, 02:06 PM | #1 |
Rep 154
Intermediate Steering Shaft Help
Has anyone here tightened all 3 bolts or removed and replaced the steering shaft before? I am thinking I might have a bolt loose due to a clunking noise I am experiencing (after eliminating all other suspension parts as suspects). I can just get to the bolt on u joint that connects steering shaft to the rack spindle. I am curious how to get to the u joint that connects to both the intermediate shaft and the steering column. There is a bolt on the firewall side (shaft side) that I want to check for tightness but there are a lot of items in the way. I can get to the bolt on the column side via the access through the footwell.
Thanks in advance. |
08-25-2023, 07:37 AM | #2 |
mTekMods
2161
Rep 2,912
im pretty sure that bolt by the firewall you can get to with a 1/4 swivel and e10 plus a few extensions.
08-25-2023, 08:22 AM | #3 |
Rep 154
Thanks!
After digging some more last night I realized it is findable after taking off the cabin filters and the trim piece beneath the filters. It is a tight squeeze however. My 3/8" drive E10 bit on a couple of wobble extensions was a little too wide to get in there. I am going pick up a 1/4" drive E10 Saturday to see if it does the trick. |
09-09-2023, 04:11 PM | #4 | |
Rep 149
09-09-2023, 10:51 PM | #5 |
Rep 154
After checking a lot things with no luck and replacing my end links to no avail (control arms replaced 8 months earlier) and installing Ohlins R&T, I did all could think and I took it to my Indy for a diagnosis. They diagnosed it as a steering rack going bad.
DIY’d today with some help and also swapped the steering shaft just in case. Clunking noise is gone. It’s so much better. Couldn’t believe the amount of noise I would get on certain pavement conditions in the cabin. I checked my steering rack and u joint I ou,led and they seemed ok. FYI there are some videos on YouTube for steering rack replacement (fcp euro on 328i) which isn’t exactly the same but is helpful to reference. Took 6 hours. Saved a little over 1100 dollars doing it myself but it was a solid 6;hour job running into a coupe of roadblocks. Good luck! |
09-09-2023, 11:26 PM | #6 | |
Rep 149
