09-11-2023, 09:26 AM | #1 |
Rep 28
Engine oil below min warning, but measures at "max"
I get the "engine oil below min" warning maybe every third time I start up the car. I don't want to run it with low oil so I've added at least 3 quarts of oil in the past 500 or so miles. However when I measure the oil level it always says that I'm at the max and I don't want to add more for fear of overfilling it.
Any ideas? |
09-12-2023, 06:09 AM | #3 |
Rep 196
You definitely have too much oil now. I advise you to do an oil change, remove everything that is there and put in the right amount (6.5L) and then see if you still get the message. There can't be 3 liters of oil missing so now there is too much and sooner or later it will throw it out of you somehow and it won't be pleasant.
09-23-2023, 05:16 PM | #4 |
Rep 28
Thanks for the suggestions. I changed the oil level sensor, drained the oil and filled the right amount. I thought it was all fixed but the oil level warning came up again the other day. A measurement indicated max. What else could be the issue?
09-23-2023, 06:38 PM | #5 |
Rep 490
When you drained the old oil did you get a rough measure of how much you had in the engine? I like to see I am in within a 1/2 quart or so of expected when I'm dumping the old oil back into jugs for recycling. (and expecting ~1/2 quart or so to still be in the engine)
10-19-2023, 12:03 AM | #8 |
Rep 1,067
10-19-2023, 06:45 AM | #9 |
Rep 28
Great timing. The software update actually didn’t work. It’s still doing it. The car is back at my mechanic as of this morning. Will report back if I find anything.
papasmurf_m3454.50 |
10-20-2023, 03:27 PM | #10 |
Rep 844
Did you swap oil level sensors?
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+ |
