09-17-2023, 10:24 PM | #1 |
Rep 60
Hardwiring Dash Cam - Do I need Add-a-Fuse?
Hi guys,
I am looking to hardwire my dash cam using this hard wire kit, which already has a fuse built into the wires. However, if I were to tap into an existing fuse, wouldn't I have to remove that fuse and use an add-a-fuse ? If so, the add-a-fuse also has a wire going out which I do not need since the wires from the hardwire kit already has fuses attached. In this case, what do I do? I tried searching but there's no add-a-fuse "adapter" that goes from 1 to 2 fuses without the extra wire at the end.... |
09-18-2023, 01:23 AM | #2 |
Rep 3,007
I just finished wiring my E92 M3 with a new 70MAI dash camera that has a very simliar harness. ACC+ 12v was hooked up to fuse #5 and then 12V source was hooked up to fuse #73.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
09-18-2023, 11:29 AM | #3 |
Rep 60
Were those fuse locations empty or did you just remove the existing fuse without replacing it using add-a-fuse?
09-19-2023, 10:18 PM | #4 |
Rep 3,007
Fuse #5 is empty and #73 was add-a-fuse kinda thing.
11-15-2023, 06:26 PM | #5 |
Rep 721
The fuse at the end of the wiring harness. Can you tap into that and add a fuse?
If not, cut just behind those fuses, strip the wires, buy appropriate fuse taps and wire it up. |
