09-24-2023, 02:14 PM | #1 |
Rep 57
Drives: 2021 330i xDrive (M Sport)
Aux Battery Replacement
After 8 years and 130k miles, the main battery finally gave up. I replaced it with the Duralast one from Autozone and registered via BimmerLink. My question is if it’s a good time to replace the aux battery as well? I’m not sure which signs to look for, or how to check its health? And yes, I did my homework both in and outside of the forum’s discussions but couldn’t really find answers for my questions. Lastly, if you could please point to a replacement battery for the aux, that would be much appreciated! Thanks in advance!
Current Drive: 2021 G20 330i xDrive M Sport
Gone but not Forgotten: 2015 F15 X5 xDrive35i, 2011 E90 328i |
09-24-2023, 08:21 PM | #2 |
<3 Flat Four
217
Rep 754
I believe AC DELCO seems to be the only one that makes a battery with similar physical dimensions n battery specs.
2011 335is Le Mans Blue
2016 X5 xdrive 35i Alpine White |
09-25-2023, 09:22 AM | #3 |
Rep 7,551
AGM LN1 which is a 140R/H4 battery class size for the auxiliary battery. Rock Auto sells it and I believe (from the past aux battery threads)...the AC Delco brand can be purchased from a GM dealership. (?)
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
09-25-2023, 04:28 PM | #5 |
Rep 57
Much appreciated for all of your replies. Ordered one from Rock Auto. Can’t wait to install
09-26-2023, 11:00 AM | #6 |
Rep 210
Typically not too many warning signs.
Atleast with my F10 which had intergral active rear steering, the low aux made the system go on the frits. The batteries were a bit uncommon years ago and the dealer got my wallet on that one
2018 X5 50i [AW / Black]
2016 550i [AW/ Black] 2014 550i [CB / Black] |
09-26-2023, 07:28 PM | #7 | |
Rep 7,551
Just some reminders…don’t forget to vent the aux battery (since it is enclosed)…there should be a little black elbow that connects the vehicles vent tube to the vent hole in the side of the battery. Don’t throw that little black elbow away when you remove the old aux battery. Also, don’t throw away the little red protective cap over the positive battery terminal on the new battery BEFORE removing the knock-out plug that is designed into the cap. You’ll need that little plug to close off the other side of the aux battery so that the gases vented by the battery don’t release inside the vehicle…but will go out the vent tube to the exterior. You can see the knock-out plug circled in green in the pic below…again, you’ll need it to plug up the hole on the opposite side of the battery you connected the vent tube to (see 2nd pic below for little black elbow that connects the gray vent tube to the battery):
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-26-2023 at 07:37 PM.. |
bavautosport43.00 |
09-28-2023, 03:47 PM | #9 | |
Rep 57
09-28-2023, 04:49 PM | #10 | |
Rep 7,551
Yes...but it can also depend on your options...but most f15 X5s have a dual battery setup...with the PCU (power control unit) sitting between them. The PCU monitors/assists the aux battery which is why it may last a bit longer than the main battery. If you remove the plastic cover below the rear of the cargo floor...you can verify if you do or don't. The smaller aux battery will be to the right of your main battery.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 09-28-2023 at 05:05 PM.. |
50iXman34.00 |
