10-18-2023, 08:45 PM | #1 |
Rep 28
VIR Track Day with G87 M2
![]() Featured on BIMMERPOST.com Wow, just wow. The car (bone stock) is seriously impressive. Hopefully not offending anyone with this statement, but I’m convinced that everyone complaining about the mass of the car simply hasn’t driven it anywhere close to the limit. You simply can’t tell that it weighs so much. The car had two wheels off the ground at 90ish hopping the curbs on the climbing s curves repeatedly, and the suspension didn’t bat an eyelash. I’ve owned lightweight cars prior to the g87 and yes they do feel more lively at street legal speeds… so I get it, with street driving as the primary point of reference. But from a pure performance standpoint, don’t listen to the armchair race engineers. We basically got a ton of refinement in this G generation car with no performance trade off versus F gen BMWs. In fairness I’m scared to look at my brake pads… I’m sure the weight means it is going to eat expensive consumables… but purely from a feel and speed standpoint, it’s pretty magical what they’ve done with this chassis. Brake feel was incredible and the car responds incredibly well to trail braking. It’s quite easy to manage the weight balance smoothly and get the nose where it needs to be. Brakes with stock pads and fluid had zero fade over 6 sessions in 2 days. I was a little worried because I read a few horror stories on the m4 board but clearly the guy either was dragging the brakes or forgot to remove the duct covers. My complaints about modern BMW steering feel went away on track. You can tell exactly what’s going on with the front end. Purely from a speed standpoint, the car easily kept up with and passed gt4s, gt500s, gt350s, m4s, c8s, etc. Caught/passed all kinds of machinery in both the corners and on the straights. I gave one point by all weekend long, to a heavily modified c8. Candidly my only complaints were: 1 The exhaust - it’s just not really loud enough to rely on sound to pick your shift points with all of the other (likely louder) cars around. Ended up leaving it in auto with the occasional manual short shift for certain corner exits. Too much going on to always be looking at the tach. 2 The last 10% of the throttle travel felt a little “sticky” - maybe just my car? Going to have the dealer look at it… obviously smooth is fast, but the last 10% of pedal travel sometimes required an extra dose of pressure to go full throttle, which made it difficult to get to full throttle in the corner exit without accidentally upsetting the balance of the car. Found myself being a little reserved and hitting full throttle after getting the wheel straightened back up to avoid a silly mistake. Anyone else felt this or just me? |
46
Bumpinjeep6752.50 aerobod4536.50 apez857.00 BMR.WRLD419.50 CadolinaRipr445.50 ronin130131129.50 HulkMansfield73.50 Searay55555382.00 WolfMPower19.50 mrdudley652.00 BMW DIY Guy3800.50 bmwimsafan29.50 j1valverde80.00 jad4ca5.50 mzimand152.00 nathanm4692.50 KevM2773.50 F32Fleet4013.50 deleted_807865_k0a0df9ee6876.00 JJacksonIII915.00 mathys220.00 Jimc44.00 MT6792.00 middyM129.00 ///M TOWN33443.00 Cmassey3441.00 2011ninja3465.00 MisanoblueZ42907.00 M3 boi3224.50 Resjudicata1616.50 MaC-N54-E82633.00 cfm56d7b6859.50 GuyOh1253.00 jpf34016.50 Needsdecaf8918.50 sclouzon18.00 rippernash76.50 |
10-18-2023, 09:35 PM | #2 |
Rep 20
Drives: G87 M2; 986, 911SC alum
Great report. Great racetrack. Tell us how it did on Oak Tree? I imagine if mass was truly a problem for the suspension, the stomp on the brakes, weight transfer to the front, turn and accelerate would unmask issues, especially coming out of it with 718s and Corvettes.
F32Fleet4013.50 |
10-18-2023, 09:47 PM | #3 | |
![]() ![]() ![]() ![]() 1899
Rep 943
how did it do vs #91 Camaro? I just sold my 2018 SS 1LE (which performed flawlessly in over 50 track days), and am waiting for my G87 to arrive (also BSM) as it's replacement. If it does at least as well as the 1LE on track I'll be happy. Second question - pictures of the front tires? How did the outside shoulders do as far as wear? How did the car handle mid corner with stock camber? Thanks again.
G87 M2 BSM On Order
10-18-2023, 09:49 PM | #4 | |
this is the way
21042
Rep 9,154
Page 118 of the Owner's Manual. |
10-19-2023, 05:57 AM | #5 |
Rep 28
Oak tree was not very dramatic…no issues. braked at the 2 board hard and then trail braked all the way through apex before the back straight.
If anything, rollercoaster is the corner that seemed like the car was having to work its computer magic the most…. Being hard on the brakes while also turning the left kink to set up the right hander makes the back end want to party for 0.2 seconds and then the systems figure it out. No scary moments you can just tell there’s a lot happening in the software with the elevation, camber, and movement of mass all happening at once. Thanks for those that replied on the throttle - it was definitely the kick down on the accelator. What I experienced was what felt like inconsistent pressure required to get past the initial “kick down” point of resistatsnce to get into full throttle. Could have been in my head but it felt a little inconsistent. Much less impactful in sport or sport plus because the throttle shape appears to not rely on that last 10% of travel as much, but it’s quite a big deal in efficient where a lot of power comes from the kick down travel. Probably a mistake, but when it was a little wet outside I ran it in efficient to tone down the throttle response thinking that would be a bit safer when grip was low. In hindsight it was probably the opposite because of the inconsistent feel I’m describing. Car kept up with stock Camaros easily. The one pictured was far from stock… different engine, full cage, full suspension, dry dump oil system where the trunk should be, and r compound tires (im on the pilot sport 4s).. Traffic was a factor all weekend with a sold out event.. so can’t really compare hot lap times perfectly.. but that heavily modified Camaro was about 7 seconds faster per lap. It was in a different run group so I didn’t drive along side it. Stock, my money would be on the g87 based on the number of camaros passed over the weekend. |
10-19-2023, 06:22 AM | #6 |
Rep 28
Forgot to answer the mid corner handling question…I was really impressed with how the nose responded to throttle steer mid corner. It was all just very linear and easy to drive. When you lift smoothly, the nose predictably tucks in, and then you get back on it, the car predictably tracks back out. With how well the car trail brakes and responds to throttle steer, there’s very few parts of the lap where the car was happier coasting… just the fastest part of the uphill S curves where I hit my current limits as a driver.. everything else was happy with immediate transitions from trail brake to gas.
Granted it was only for 10 minutes or so, but I spent a small amount of seat time in the z4/Supra chassis at the Greenville handling track…. That car was the exact opposite, it was very quick to get upset and swing the rear in lots of scenarios that the g87 wouldn’t even notice. I’ve read the commentary on the Supra being “more rewarding when you get it right”, but honestly that’s not my thing in the real world.. in my own, one and only street car with a big track insurance deductible, I’ll take super linear corner entry/mid corner dynamics over the knife edge any day of the week. Pointy cars are fun/fast on the sim but based on what I felt, I’m not sure i’d feel comfortable really pushing a Supra all the way to limit without a LOT of seat time in that particular chassis. |
CadolinaRipr445.50 BackOnBlack1420.50 |
10-19-2023, 07:48 AM | #7 |
![]() 122
Rep 126
Great review, VIR I think is the closest track to me - I hope to go to an event next year. I have a buddy who raced in F3 who basically is my coach whenever we get on the simulator, I actually watched him race at VIR a few years ago.
10-19-2023, 10:40 AM | #8 |
Platinum Member
437
Rep 288
Good write up!
I agree, it doesn’t feel that heavy. 3700lbs for a modern car isn’t that much. Especially considering it has been consistently putting down 470+whp. people are just whiney for the sake of arguing. It’s a fantastic overall package. |
10-19-2023, 10:47 AM | #9 |
Primo Generalissimo
![]() 5217
Rep 4,303
Drives: All of them
Garage List 2025 BMW M850i [10.00]
2024 Ford Bronco Ra ... [10.00] 2018 Porsche 911 GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Nice report. I'm still in break-in and while I won't say it turns as well as my 718 or 911, it's very close. It's also very flat and planted in turns. The automatic is almost DCT-like and much better than the C7 auto I used to own. It's very quick to shift up and down.
10-19-2023, 12:25 PM | #10 |
![]() 1976
Rep 1,458
Was there with you. We were in the M5 CS. My girlfriend thinks she remembers seeing you. We did happy hour first day, but skipped happy hour second day (I had corded my Pilot Sport Cups by then). We both love that car.
Shawn |
10-19-2023, 12:28 PM | #11 | |
![]() 1976
Rep 1,458
Shawn |
G30 B581631.00 |
10-19-2023, 12:55 PM | #12 | |
![]() 1976
Rep 1,458
From the manual... "Kickdown Kickdown is used to achieve maximum drive power in Drive mode. Step on the accelerator pedal beyond the resistance point at the full throttle position." Kickdown and 100% throttle differ how? When I'm on track, coming out of Oak Tree, getting to that detent and pushing through it doesn't shift the transmission into a lower gear. It's already doing it's best in full performance mode. It may CERTAINLY not be what you experience in grandma mode hauling the kids to school, but it is for certain a 100% WOT on track - and not 100% before you hit that. Shawn |
10-19-2023, 01:08 PM | #13 | |
![]() 1976
Rep 1,458
I still completely disagree. "kickdown" on old cars was a simple mechanical switch that was engaged at 100% accelerator pedal, and there was no "logic" other than mechanical in the transmission. It only knew to downshift by this switch. What you're saying is that 100% throttle is achieved at the end of the accelerator pedal (before the detent). I can tell you from the BMW laptimer telemetry this is NOT the case. I no longer use that, because I use a Garmin catalyst now. But my old telemetry told me I wasn't getting 100% throttle without going through that detent. But, honestly, you're telling me that kickdown and 100% throttle differ. I don't agree. My telemetry doesn't agree. But, you got evidence to the contrary? Go for it. Shawn |
10-19-2023, 01:19 PM | #15 | |
![]() 1976
Rep 1,458
And, BMW laptimer may be crap (yeah, it's kind of the reason I got a Garmin anyway), but it absolutely told me I was at 99% throttle until I got through the detent on track. Could it be wrong? Sure. But I can say, the car accelerates a LITTLE better when I push through that resistance. A lot better? No. But goodness, the difference between 99% and 100% is pretty damn hard to tell from butt dyno. I haven't done OBD tracking yet on the throttle pedal for sure. But, for me, functionally from old cars, 100% throttle and "kickdown" were basically the same. (cause it was the same gas pedal position). Did BMW add it as a different function? Hell, considering some of the other sh** that they do, maybe? But, then again, really, 99% and 100% throttle mean very little in the real world - except at the back of VIR straightaway at 157mph. Shawn |
deleted_807865_k0a0df9ee6876.00 pyrorupt3.00 |
10-19-2023, 01:24 PM | #16 |
![]() 1976
Rep 1,458
And, not used to this interpretation. Sorry. Maybe background.
This is what I'm used to. https://www.dictionary.com/browse/goodness interjection Also my goodness or goodness gracious . (used in expressions of surprise, alarm, etc.) I don't mean surprise to be condescending. So, yeah, sorry about that. Shawn |
deleted_807865_k0a0df9ee6876.00 imperfectluck571.00 |
10-19-2023, 02:29 PM | #18 | |
![]() 1976
Rep 1,458
I'm the same as you. All other things being equal, I don't like it when the rear goes all squiggly. Maybe fast, but not fun for me. Shawn |
deleted_807865_k0a0df9ee6876.00 |
10-19-2023, 03:16 PM | #19 |
![]() ![]() ![]() ![]() 792
Rep 465
Thorough reporting keep it up
Kevin_The_Clean14744.50 |
10-19-2023, 03:35 PM | #20 | |
![]() 3949
Rep 1,767
I also totally agree on the front end, even on public roads the eagerness and precision of the G87 surprised me. The feedback is dead, sure, but that doesn't prevent you from putting the tires exactly where you want them. I put it down to a combination of the high steering ratio, 275s in the front, and shorter wheelbase. |
10-19-2023, 04:02 PM | #21 |
![]() ![]() ![]() ![]() 1113
Rep 704
i'm not sure a car weighing 400lb more is passing a GT4 or a C8 . Let's be honest they probably werent going all out.
I plan on driving my friends M2 next season at NJMP to see for myself but overall your track review is positive in my book and thank you for sharing |
