10-20-2023, 03:05 AM | #1 |
Rep 5
DCT Doesn't Rev Match - Software Issue???
After getting to operating temperature in my 2015 F80 M3 and then parking for 5-10 mins, then starting it and driving off, the DCT suddenly forgets how to rev match when slowing down into second gear. Here are two instances of this happening (take note of the noise and the visible jerk when this happens):
Slowing down from 50km/h Slowing down from 20km/h, you can see the camera shaking too when the DCT downshifts to second This happens for 2-3 minutes when I start driving, and goes away afterwards. There are no error codes, and the DCT behaves 100% normally otherwise. There is another issue that happens sometimes under the same conditions (Parking the car warm, and then driving off a few minutes later), where the clutch seems to engage and disengage multiple times when up-shifting into second gear and accelerating. This causes a repetitive clicking noise that happens for around a second, where it clicks 5-6 times and the car does not accelerate. I brought it to the dealership for diagnosis, but they couldn't reproduce the issue, which makes sense as I only encounter this issue once or twice a week. Any help would be appreciated! |
10-27-2023, 02:03 PM | #2 | |
Rep 138
Occasional jerk while slowing down, in my case was fixed 95% via gts dct flash. Happens rarely these days assuming adaptation took some time to learn. Last edited by F82///M; 10-27-2023 at 02:12 PM.. |
csboi379.50 |
10-27-2023, 03:41 PM | #3 |
Rep 1,371
Why would a DCT need to rev match when it can literally shift while in gear???
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
10-27-2023, 06:14 PM | #4 |
Late Apexer
380
Rep 165
To reduce wear on the clutches.
2018 BMW ///M3 CS • San Marino Blue • MPE V2, VRSF SMP, KW HAS, GC CPs, SPL FLCAs + TREs + RUCAs + F&R ELs, Fall-Line RTLs, Team Schirmer offset RDB, Michelin PSC2★, MSI 80mm wheel studs, Core4 FC lug nuts, CSF CC, ESS Tuning CPs, MSR FMCAI, Dinan coils, SLON Workshop tie bar, Endless ME20 + RF650
10-28-2023, 04:22 PM | #5 |
Rep 2,786
Drives: 2020 M4 ZCP / 2023 X3 M40i
This is like asking why would a stick shift driver need to rev match when he can use the clutch.
10-28-2023, 04:32 PM | #6 |
Rep 1,371
Rev matching makes sense for a manual. For a DCT, the shift takes a nanosecond. But one could always argue that they're real drivers doing real things like yourself. BTW, you spelled shift wrong.
10-28-2023, 07:16 PM | #7 |
Late Apexer
380
Rep 165
Dude you have your answer. Believe it, or don't. What more do you want?
Hope this helps - https://auto.howstuffworks.com/dual-...ansmission.htm
Tags |
dct, downshift, jerky dct |
