10-25-2023, 09:12 AM | #1 |
Rep 106
Can you mix BMW blue and new green coolant?
Just found out my dealer added/used the new green BMW HT12/LC18 to top off my MY15 35d during the recent EGR recall work while checking coolant level in expansion tank and coolant color is green and not very clear. In the past, blue BMW G48/LC87 coolant was there and pretty clear, and I always used BMW blue G48/LC87. Should the mixed coolant be flushed and replaced either BMW G48/LC87 or HT12/LC18, so don't need worry about the mix may has/cause issue down the road?
10-25-2023, 09:34 AM | #2 |
Rep 7,548
Based on info from the BMW TIS...the old blue G48 & the new green (or magenta) HT12 can be mixed. Not sure what color you come up with...but they claim to be compatible.
What is NOT compatible is the blue i3 coolant or the magenta G30 coolant.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
10-25-2023, 10:37 AM | #3 |
Rep 106
Thank you for the quick response, Qsilver7. Any ideal what ! means by green bottle of HT12 at left/lower in the picture? Also, looking the 2 tables, for our F15s, 1 table shows both can be used after 01.07.2018, but the other shows only blue G48 can be used in before 03.06.2018.
By compatible, definitely it means you can use either of them, but would mixing/topping them in cooling system OK like my dealer did? Just want to get to the bottom of this, to make sure we do the right things for our Bimmers! |
10-26-2023, 12:15 PM | #5 | |
Rep 7,548
In regards to the two tables...the top table has a date which indicates when HT12 was introduced & used on those particular models. Prior to that date...the lower table was used which indicates those models came from the factory with the old G48 blue coolant. The tables are just representing what color/type of coolant was used in your BMW at its time of production. But as stated, both the G48 and HT12 have the correct "inhibitors" for your BMW and are compatible.
