11-28-2007, 10:50 PM | #1 |
Remember
37
Rep 115
Importing just the clear/white front corners
Who or which organization, if not my local BMW dealer, do you think would be the first to "import" those white/clear European front corner lens to the U.S. -- as "grey market" or whatnot? I think it'll be my first mods, hell with regulations. I'm also assuming it'll take regular tools, to swap it in the privacy of my own garage. :headbang:
Clear front corners in France: Ambers in San Francisco Auto Show: (photos borrowed from others... credit where credit is due). |
11-28-2007, 11:09 PM | #2 |
Rep 4,190
It would be great if it was just a matter of removing a color slide rather then changing the entire housing. Wouldn't this be the more cost effective way to do it from a manufacturer's point of view?
11-29-2007, 12:23 AM | #4 |
Rep 799
11-29-2007, 10:45 AM | #5 |
Rep 2,218
^ yes, but to remove, you must heat up the lights to spread them apart...
I'm not sure about you guys, but I'm not putting a headlight tha has motors (for the moving hid's) attached to it in my oven... Unless there is something new, last i knew, on e90 post you had to buy the whole headlights for the e90's. I would assume the 1er would be the same, but I could always be wrong... I baked/removed the amber in my `02 RSX-S. It was quite easy, but I dont see myself baking the 135i headlights, unless you can dis-assemble them to the point that no motors are on them...
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17- - 2015 CPO i01 BEV Laurel Grey Tera World, '17- - 2015 i01 REx Laurel Grey Tera World, '15-'17 - 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15 |
11-29-2007, 11:05 AM | #6 | |
Remember
37
Rep 115
But I totally agree about NOT doing it if it requires heating. I don't think heating a piece of plastic is considered "regular" mechanical repair activity, especially if there are attached devices to the housing. Then again, I do own this particular tool for my business, and I know how to use it properly... :headbang: |
11-29-2007, 12:29 PM | #7 |
Rep 2,218
^ yeah, we did another friends car with one and a bunch of flat-headed screw drivers, it worked, kinda, but I guess we were impatient because it left a lot of marks on the frist one. The second did, however, turn out better...
This was a long time ago too, so he might just not have known how to use it properly...
11-30-2007, 06:02 PM | #9 |
Rep 141
It depends.... on my s4 there are 3 yellow tabs that u can heat up with a sodering iron tip and pop out the yellow amber.... then break it up and pull it through the bulb hole. Then use something to cover up the hole so no moisture gets in there.
12-05-2007, 03:07 PM | #11 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
same issue as in the E90, crazy xpensive headlight set if u buy from europe!
12-07-2007, 11:18 AM | #13 |
Rep 2,218
Do ED and find some crazy 1er owner that wants amber up front, pick up the car, swap them out, do the ED thing, return the car and have it delivered to your dealership with the clears...
Far fetched idea, but it is an idea...
12-30-2007, 03:14 AM | #14 | |
Addicted Member
15
Rep 603
I like the clear look w/Orange Bulbs better myself.
[SIGPIC][/SIGPIC]
02-21-2008, 10:48 AM | #17 |
Rep 2,127
Drives: E92
just smoke the lights or custom fab a set of eyelids that will cover some of the amber:iono:
"Go with Ray's. His e92 is God." - mashimarho
02-25-2008, 10:18 AM | #18 | |
PCA, BMWCCA
102
Rep 2,058
Of course I'm just kidding...
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
02-26-2008, 11:04 AM | #19 |
Rep 2,127
Drives: E92
Wow you would have to have BALLS to do something like that
02-27-2008, 02:07 AM | #21 |
Rep 3,094
04-04-2008, 02:18 AM | #22 |
Michelin Man
388
Rep 740
Has anyone disassembled the headlights to see if the amber parts inside can be removed? It does look like the entire headlight assembly would need to be replaced, too bad the corner lenses are not separate pieces.
