11-19-2023, 04:16 PM | #1 |
Rep 67
E92 DCT Leak Help
I’ve researched a ton on these and recently did a transmission flush with new bottom pan and all seals. It seems to still be sweating from the pic attached. Anyone else here that has sean a leak from the circled area, or any help on how to fix it?
11-19-2023, 05:33 PM | #2 |
Rep 1,128
Search for mechatronics harness o-ring in the DIY section of this site. You might need a borescope/endoscope to see the source of the leak up top.
11-19-2023, 05:36 PM | #3 |
Rep 1,128
If not that o-ring check the pressure filter cap area for leaks. Clean everything off with brake cleaner run the car for a day and inspect for leaks. Alternatively you can add fluorescent dye to the DCT oil, run the car and shine a black light on the car to trace the leak.
