11-22-2023, 04:55 PM | #1 |
Rep 149
Weird rubbing noise when turning, Rear Diff?
I think this has been addressed on here before. But when making turns, specifically lower speeds on a turn, there is a sort of groan/rubbing noise coming from the bottom of the car. I’ve heard that is usually the rear diff and the fluid just needs to be changed. I just got it changed recently and it is still making that noise. I think the weather being 40 degrees also affects it because it has gotten worse/louder now compared to the summer when it had just started. Any ideas on what I would need to do to get this fixed. I used the Redline diff oil. 59k miles on the car.
I will try to add some videos on here. |
11-22-2023, 05:02 PM | #2 |
Rep 1,128
Either tire rub or LSD. Get used to it or put slip additive in your diff oil. Your first time with a car that has an LSD? They all bind to some extent. Especially if they have an aggressive lockup. If you do a flush and use regular diff oil that meets bmw spec but doesn’t have slip additive, this is par for the course.
11-22-2023, 05:13 PM | #3 | |
Rep 149
11-22-2023, 05:17 PM | #4 | |
Rep 149
11-22-2023, 05:23 PM | #5 |
Rep 1,128
I wouldn’t bother. That’s how I know it’s working. But if you really hate it figure out what slip additive bmw recommends. Regular redline doesn’t have any as I recall.
11-22-2023, 05:25 PM | #6 | |
Rep 149
Thanks for the help brother : ) |
11-22-2023, 08:01 PM | #7 |
Rep 59
That's the wrong gear oil. Either add friction modifier to it, or you could use this Red Line gear oil:
https://www.fcpeuro.com/products/5w1...-1-quart-57914 This is what I use and it works great on both street and track. Good luck |
11-22-2023, 08:17 PM | #8 | |
Rep 149
11-22-2023, 09:23 PM | #9 |
Rep 892
Drives: F87 M2CS
Can you post a video of the noise?
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
11-22-2023, 10:08 PM | #10 | |
Rep 149
Still makes the noise though may need additive. |
11-23-2023, 12:04 AM | #11 | |
Rep 195
