01-23-2008, 01:33 PM | #1 |
Rep 25
Alarm system + Comfort Access
I just found that the alarm system does not come standard on 135.
Does anyone know if dealer installed alarm will work/integrate with Comfort Access FOB? and how much (parts & labor) would be reasonable from your experience... or if DIY is possible? Thanks in adv. |
01-23-2008, 03:11 PM | #2 |
Rep 10,176
The dealer installed alarm system integrates with the car/fob completely, and can be installed by you, but needs to be activated by your BMW Center, since there's programming settings involved (regardless if you have CA or not).
01-23-2008, 04:00 PM | #3 |
Rep 7,594
Drives: '19 M2C
I have done the install on three BMW's and it's really easy.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
01-23-2008, 05:15 PM | #5 |
Gato Grande
Rep 180
Drives: '08 X5 3.0 SI
That's nuts no Alarm System??? Ok - well maybe my buddy Chriskurn will teach me how to install it...
John
01-23-2008, 05:55 PM | #6 |
Rep 10,176
I believe all cars since the e90 come with the motion/tip sensor built into the ceiling mounted lighting. All you need to do is take off the side lining in the trunk, screw it down, and plug it in. The harness is already there.
You still have to have your BMW Center activate it though. If you're definitely going to buy one, ask your Client Advisor if the programming will be free. Normally, they will charge you one hour labor. CA's are a little more generous on delivery day, and you may get him/her to agree on them programming the car for the alarm for free. |
01-23-2008, 06:09 PM | #7 |
Rep 131
e9x, e83, e85, and the 1 do not come with alarms. They however all come prewired for an alarm system. The alarm install consists of a hood switch, interior/motion sensor, a siren and a recode to activate. on an e9x, you can do the install in about 15 minutes. but it depends on how quickly you can remove the left rear wheel for the siren install. i believe the system is around 350 plus labor.
01-24-2008, 12:44 AM | #11 |
Rep 2,127
Drives: E92
yes, at least its like that on the E92
"Go with Ray's. His e92 is God." - mashimarho
01-25-2008, 09:48 AM | #12 |
Rep 186
BMW assist lowjack function?
Speaking of alarms, the sales associate I spoke with yesterday says that the 'BMW Assist' program functions as a lowjack locater if the car is stolen.
My sense is that contemporary cars are a lot harder to steal than historically, maybe the recovery capability is all you really need... |
01-25-2008, 09:52 AM | #13 | |
Rep 7,594
Drives: '19 M2C
Check this out: http://www.e90post.com/forums/showthread.php?t=1487
01-25-2008, 09:54 AM | #14 |
Rep 7,594
Drives: '19 M2C
Here are the parts for a e87 130i. Not much to it.
http://www.realoem.com/bmw/showparts...87&hg=65&fg=60
01-25-2008, 10:26 AM | #16 |
Rep 7,594
Drives: '19 M2C
On the 1er is looks really simple. I can't image the 135i would be any different. :iono:
01-25-2008, 10:29 AM | #17 |
Rep 7,594
Drives: '19 M2C
Here are the parts for a e90 335i: http://www.realoem.com/bmw/showparts...87&hg=65&fg=60
Looks like BMW has simplfied the install in the last couple of years.
02-22-2008, 12:33 PM | #18 |
Rep 6
Well when I ordered my E46 325i, I got the alarm as a factory option so once the car got here, they installed the alarm free of charge since I ordered it with the car.
Don't know if that still applies though. |
02-24-2008, 03:03 AM | #19 |
Rep 30
Factory purchased/installed alarm and Comfort Access system aside, does the car come with keyless entry (i.e. remote lock/unlock or do you actually have to stick a key in the door)?
The 135 will be my first Bimmer. |
02-24-2008, 01:22 PM | #21 |
Rep 131
all bimmers come with keyless entry. an actual key slides out of the remote in case of remote failure.
03-16-2008, 01:39 PM | #22 |
Rep 67
Once you have the system installed (standard on UK cars), how do you disable the interior protection when necessary? - Can't seem to see this in the handbook. Oh, I have comfort access if that makes a difference.
