      01-27-2008, 01:36 PM   #1
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Xenon Color Shift?
Anyone know if the colorshift time frame on the xenon is still 150-200hrs?
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      02-05-2008, 01:38 PM   #2
Russo
Commander
Russo's Avatar
Drives: 09 Dodge Dakota Big Horn
all HID kits i've had change colors within 15 seconds.... i could be confused to the question though...
      02-06-2008, 06:23 PM   #3
Kris
Drives: m3
That depends on the bulb. If its the Philips 5k then yes, they will.
If they are the Osram/Philips 4300k, no. But the Philips 4300k will had more of a purple/blue tint over time...
      02-07-2008, 07:25 AM   #4
ChrisK
ChrisK's Avatar
Drives: '19 M2C
No, I am not talking about the warm up after ignition. All xenon bulbs start out a tad yellow until they basically break-in. Then the 4100k Philips/Osram OEM HID D2S turn white.
Actually Kris the OEM bulbs are not 4300k like the kits, they are 4100k (4100 k Philips/Osram OEM HID D2S).
Here is an OEM DENSO ballast and 4100k OEM bulb kit I had.
You can see the bulbs brand new, then the color shift after 100+ hrs.
      02-07-2008, 07:31 AM   #5
BForbes
Moderator
BForbes's Avatar
Bahamas
559
Drives: BSM 135i/AW E90 M3
Wow. You learn something new every day. I had to idea a xenon bulb's color shifts.
- 04 Honda S2000(gone)
      02-07-2008, 07:39 AM   #6
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Get source of info: http://www.hidplanet.com/forums/
You may have to register.
      02-07-2008, 07:44 AM   #7
BForbes
Moderator
BForbes's Avatar
Bahamas
559
thanks^^^
      02-07-2008, 03:28 PM   #8
Kris
Drives: m3
OEM Bulbs I got from BMW are infact 4300k, not 4100k as you've stated.
As I mentioned, some of the BMW's come with OEM 5k bulbs, 85122+ they are labelled as. These color shift after about 100hrs.
The picture you've shown is a D2R bulb, I dont think any of the new BMW's have D2R reflector based bulbs. They are all D2S
      02-07-2008, 04:54 PM   #9
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Philips/Osram doesn't make a 4300k bulb for the US market. 4100k is the only temp bulb legal in the US. That may explain your bulbs in Australia.
D2R are only for reflector housings, no BMW with projectors have ever used them. They us D2S which are for projector housing. The only difference between the bulbs is a coating on the D2R to reduce glare.
The bulbs I show are D2R with the coating removed, now it's a D2S.
      02-07-2008, 04:59 PM   #10
ChrisK
ChrisK's Avatar
Drives: '19 M2C
OEM Specs:
Philips D2S burner specs:
Lamp Power = 35W
Lamp Current = 0.45A
Base = P32D-2
Luminous Flux = 3200lm
Color Temprature = 4100K
Rated Life = 3000 hours
Overall Length = 77.5mm
      02-14-2008, 10:25 PM   #11
Russo
Commander
Russo's Avatar
whats the factory high beam bulb number?
FS: CT9A parts and Enkei Wheels!!! PST
BLUEFAKES.COM ARE SCAMMERS, LIERS, AND CHEATERS! DO NOT BUY FROM THEM!!!
1addicts
