01-06-2024, 12:14 AM | #1 |
Rep 175
Ohlins R/T + SPL sway bar links
Anyone know which length end links to use with Ohlins R/T dampers ? I'll be using the stock sway bar and running the dampers slightly lower than the recommended settings if that makes any difference.
01-06-2024, 03:34 AM | #3 |
Rep 5,813
How much lower than stock? With the height adjustment changing the length between the sway bar mounting tab and spindle mount, you may need a shorter sway bar end length. BimmerWorld offers adjustable end links in oem and shorter lengths. If you’ve changed the relative mounting locations by more than 1” I’d recommend a shorter adjustable verson. I believe BW offers one that’s stock length to 1-1.5” shorter.
