02-16-2024, 07:52 AM | #1 |
Rep 345
Rear brake caliper
Is the rear brake caliper the same with all models? 35i, 50i, and X5M? I know the mounting bracket is different for rotor size … but the single piston caliper looks identical ….
02-16-2024, 09:46 AM | #2 | |
F15 daddymobile
2355
Rep 3,520
https://f15.bimmerpost.com/forums/sh....php?t=2051224
02-16-2024, 08:16 PM | #3 |
Rep 305
I just did a 50i caliper upgrade on my 35i. Bought them used from eBay. The 35i calipers were stamped 44/20, while the 50i calipers were stamped 44/24. I didn't measure them, but I'm assuming the 50i (and M) calipers are slightly taller/thicker/whatever to accommodate the thicker 24mm rotor. However, they both share a 44mm piston.
02-28-2024, 01:50 PM | #4 |
Rep 345
So my 35i calipers won’t fit with M bracket ? Or will?
I’m Trying to use my stock “44/20” rear calipers but change the bracket that came with the f85 set. I don’t want to spend money and rebuild the f85 42/24 calipers…. Plan to go 4 pot in future … |
02-29-2024, 08:46 AM | #5 |
Rep 345
So I would like to say, you were all wrong. I have car apart and guess what. Bracket doesn’t fit ….
Sliders won’t go in … they are slightly wider … |
02-29-2024, 09:31 AM | #6 |
F15 daddymobile
2355
Rep 3,520
post a pic please. I have a 50i and i thought the 35i had the same rear as that... my bad for telling ya wrong.
