03-11-2024, 07:25 PM | #1 |
Rep 39
Sell for G8x or no?
Hi, I want some advice on soul-searching and financial concerns with driving and owning my F83.
My situation is currently:
At this point I'm kinda scared of the things that can/will fail in the future on the car given the way I've driven it. Immediately off the bat, several interior trim pieces are peeling, the oil cooler (and other radiators) don't work as well as factory on performance driving, and the suspension components are starting to wear out. Down the road, I wouldn't be surprised if I got a turbo or charge cooler failure, or even something more major such as an entire DCT failure (given the grinding noises I've been hearing lately). Today I went to the BMW dealer and did some math, and given the amount of repairs I'm expecting to do over the next few years, I can't help but think that a (stripper spec) G87 M2 would be a "better" financial decision. Yes, it costs more, but not that much more by my math (on the order of $10k more over 3-5 years), and it will spend way less time in the shop AFAICT. Plus, given that I don't tune it like the F83, if any major components fails, it will be covered by the warranty. In addition, I haven't driven one, but it seems like the G87 will be a much better car technologically and comfort-wise (with fresh bushings/dampers/everything + new tech), even compared to my F83 before I modified it. Buying a G80/G82/G83 is out of budget so don't ask for it. What do you guys think is the correct move here? Drive F83 until a major repair is needed? Sell now and buy a G87? Buy something else entirely? Stop hemorrhaging money? Open to all ears here. |
03-11-2024, 07:40 PM | #2 |
///M Powered for Life
11502
Rep 10,334
Having a car under warranty is a luxury. If you don't work on your car yourself, it's pretty expensive to keep it for a long time
03-12-2024, 04:19 PM | #3 | |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
03-12-2024, 04:27 PM | #4 |
Rep 1,371
If it's your daily, yes.
If it's your weekend or sunny day car, no.
MGM Ext, SO int, Euro IKON, CS front lip, Carbon 1.5 diffuser, GTS/CS coding, M perf rear spoiler, & everything else STOCK.
(Previous E39 and NA1 NSX owner) Those were the days! |
Sephrr288.50 |
03-12-2024, 11:25 PM | #5 | |
Rep 39
Also, I don't expect I will see 2 replacements of most of the above components before I get some major component failure like an entire engine, transmission, or convertible top which requires me to retire the chassis. Last edited by TPNml; 03-12-2024 at 11:33 PM.. |
03-12-2024, 11:29 PM | #6 | |
Rep 39
As such, my tolerance for stiff/noisy/shaky cars is higher, but I still have limits! |
03-13-2024, 12:57 PM | #7 | |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
N1rve
03-13-2024, 01:48 PM | #8 | |
Rep 3,332
OP - if you're worried about the headaches that the mods are causing then ultimately thats on you for thinking they came without the added risk and wear. If running costs are a bigger concern flash it back to stock or a more modest stage 1 tune and call it a day. The Fxx platform itself is still rather stout and in reality the price you'll pay to get into a new car likely will cover plenty of repairs and out of pocket expenses. If you're trying to factor long term ownership into the equation just based on maintenance don't forget: -Higher insurance costs on the new car -Higher finance rates if you need to take a note out -Depreciation of the new vehicle compared to yours. In almost every circumstance I can guarantee it's cheaper to run your car as is, but if you want a new car and are trying to do spreadsheet math to convince you it's a good idea then I won't stop you, we've all been there.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
03-13-2024, 02:43 PM | #9 | |
11502
Rep 10,334
Many/most mechanics will refuse to accept your parts. Even if they did accept them, FCP warranty is far from what it was. Now you pay 1600 for brakes, use them, when it's time to replace them you need to buy another set for 1600 and you get a 1600 store credit. So then, when you order your third set of rotors, at 150k miles, you get those 'free'. It's pretty close to a scam. No wonder ECS now offers the same 'store credit' scheme, because it costs almost nothing. |
03-13-2024, 03:54 PM | #10 |
Rep 259
Keep the car it’s been your pride and joy and lots of memories made. Big deal if a few more items to replace as you would have to do the same plus more tuning mods on the M2.
03-13-2024, 10:45 PM | #11 |
Rep 2,091
Just for the reason that the valves made contact with the pistons I would probably move to another car. Have you considered another f8x? Maybe try a F82 or f80 to change things up.
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
03-15-2024, 11:48 PM | #12 | |
Rep 39
03-15-2024, 11:50 PM | #13 | |
Rep 39
03-15-2024, 11:55 PM | #14 | |
Rep 39
Virtually all the mods I've done to the M4 besides the ECU and TCU tunes and sticky tires were either bought to prevent excessive wear (camber plates for tires) or to prevent parts from failing, often retroactively (crank hub, chargepipes, poly diff bushings, etc.) Obviously ECU and TCU tunes have no place on a car with warranty, and nearly every other part (save for tires and brake pads/fluid) is covered by warranty, so there is no need to mod the M2. |
03-16-2024, 12:17 AM | #15 | |
Rep 39
My next car should really have a warranty so I can just take it to the dealer and forget about it whenever it needs repairs. Modding is fun (and if I keep my current car I'm probably keeping all the mods on it), but it's not like I'm installing some special voodoo mods that are being R&Ded to create a type of car that doesn't exist. If I wanted another stiff sport coupe type car, I'm either getting a G87 or doing what I should have done from day one and get a brand new Camaro SS 1LE. |
