03-23-2008, 03:50 PM | #1 |
Rep 799
Performance Pedals DIY
This is a pretty easy mod and all you need is a small torx screwdriver, a 7mm wrench and 3/32, 7/64, and 11/64 drill bits. There are only two hard parts....putting the rubber inserts into the aluminum pedals and drilling the last two holes on the footrest...but still they are no big deal.
1. You peel off the rubber pads on the clutch and brake pedals. 2. The new pedals come with sticker templates, but they are off. So only match up the top two holes on the clutch and brake with the template and drill. The clutch is plastic, so you can easily just use the 11/64th bit and insert the screws and nuts. The brake is ridged metal and will require a pilot hole with the 3/32 bit or something smaller to avoid slipping of the ridge. Once the top two are bolted down and slightly tighted. Push on the bottom and drill in place with the 11/64th and bolt them down. Tighten all in a star pattern with a 7mm wrench and torx screwdriver. 3. The gas pedal is drilled and screwed directly to the plastic. No need for the template here. Just line it up nicely with the left edge of the pedal (it will actually overhang slighty to the right, but it looks better and no one will know), hold it in place and drill a hole with the 7/64th bit. Screw it down, and pivot the pedal if needed for a perfect line up and drill and screw the remaining holes. 4. The footrest is the same as the gas pedal. Line up to an edge of your liking and drill and screw the middle hole first. Sit back and pivot as needed until it looks straight, then drill and screw the remaining. The hardest part of this whole job is getting the last two top holes on the footrest. A drill will not fit, so you will either need a Dremel style flex drill hose or like me have to drill it by hand by just twisting the 7/64th bit around and around for 10 minutes. I was then able to screw the top two down with torx bit and a wrench. This is a very easy mod and immediately makes a huge first impression the second you open the door. The pedals feel great and worth every penny. |
03-23-2008, 04:57 PM | #4 |
Rep 4,311
Drives: Supercharged E90 M3
that looks really good!
gonna have to do this to mine...
03-23-2008, 09:18 PM | #7 |
Rep 252
where can i order the pedals from?
Titanium Silver
6 speed man Black Boston Leather Gray Poplar Trim Nav system Comfort access Power/Heated seats Sattelite radio Ipod Production number 398**** |
03-24-2008, 08:02 AM | #11 |
Rep 7,594
Drives: '19 M2C
For this application...even with lock nuts, I used Loctite on all of the machine screws.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
03-24-2008, 08:04 AM | #12 | |
Rep 1,680
thanks for a great write-up and posting those nice photos. I'll be doing this as soon as I can deal with the idea of drilling into my new baby.
e90 M3, Space Gray / Extended Black, ZCP, ZCV, ZP2, DCT
sold: 2008 BS 135i 6MT |
03-24-2008, 09:27 AM | #15 |
Rep 799
Loctite is great advice Chris, I take the time in a few day to apply some.
Lester the part numbers from my receipt are below. 35-00-0-304-642 Pedals - List $88.40 - Net $71.83 (my price) 51-47-0-027-792 Alum. Footrest - List $78.00 - Net $58.50 |
03-24-2008, 11:06 AM | #16 |
Rep 7,594
Drives: '19 M2C
Better to be safe than sorry.
03-25-2008, 02:26 AM | #17 |
E30 Addict
38
Rep 590
The CDV has to be done under the car.
03-25-2008, 03:54 AM | #18 |
PCA, BMWCCA
102
Rep 2,058
^^ CDV?
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
03-25-2008, 04:01 AM | #19 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Clutch delay valve, delays engagement to facilitate smoother shifts, or, so I'm told.
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
03-25-2008, 04:11 PM | #20 | |
E30 Addict
38
Rep 590
Actually it makes for rougher shifts. It makes it almost impossible to shift from first to second smoothly. BMW engineered it to add more wear to the clutch than the diff under hard shifts. They do this so there is less, or ideally no damage to the diff. BMW started adding this piece before the offered maint on thier cars, and currently dont offer it in other parts of the world. So it is there to add clutch wear instead of diff wear, because clutches are cheaper, and not covered all over the world.
03-26-2008, 01:18 AM | #21 |
181
Rep 2,614
Interesting. Additional motivation to perform the CDV mod.
