BMW X5 and X6 Forum 2014-Current
      03-18-2024, 10:19 PM   #1
wyowolf
Drives: 2015 X5 50i
2015 x5 Drivetrain Malfunction
We have had our x5 5.0i for about 15 months, I have been getting an occasional DM warning, it seems to be random but has crept up more and more in recent weeks...
I called the BMW dealer in Denver, we are 4 hours north of them, I had read about a recall for the BMW injectors on these engines out to 10 years or 120k. They said they had never heard of it? We are expiring next month and I have a sneaking suspicion that they are the fault... will post some codes below...
appears to be the number 6 injector
have others experienced this? were you able to get the warranty work done?
SIB 01 05 18 is the pertaining document...
I usually do all my own work on all my cars so this is something a bit more complex...
thank you all in advance...
      03-19-2024, 12:24 AM   #2
mrrsharma@yahoo.com
Drives: BMW X5 35D F15
Looks to be a coilpack on cylinder 6, switch it with a different cylinder and see if it follows.
      03-19-2024, 02:25 AM   #3
besi44
Albania
Drives: bmw xf15
2015 bmw x5  [0.00]
  [0.00]
https://www.bimmerpost.com/forums/sh...php?p=30998246
I think your problem is the coil pack and the plugs
Many cases a bad coil or a bad plug causes a misfire
      03-19-2024, 09:28 PM   #4
wyowolf
Drives: 2015 X5 50i
ok I will check those out as well... thank you both very much
xbimmers
