04-09-2024, 03:39 PM | #1 |
Rep 5
TMIC Coolant Reservoir Level
I am growing concerned about a potential TMIC coolant leak on my M4, especially after noticing the coolant level in the TMIC reservoir being pretty low. It’s not empty by any means but definitely low.
I’ve never had to add coolant to it before. Car has 66k miles on it. Can someone confirm whether or not the level in my reservoir is low enough to indicate a leak? AFAIK there’s no reason the coolant should ever be exiting the system. Apologies if this has been covered already but I didn’t see any posts with photos of the reservoir specifically. |
04-09-2024, 04:33 PM | #2 |
Senior VP of spite
80
Rep 108
Drives: 09 335i, 11 335xi, 17 X3 M40i,
The level should never change in the TMIC system, if it goes from max to min it is a good indication that you have a leak.
However, I will add my level dropped slightly once and ran the bleed procedure. I have not had an issue since.
The Olives
Current: 2015 M4, 2018 X3 M40i, 2018 Elantra Retired: 2009 335i, 2011 335xi |
04-10-2024, 05:01 PM | #3 | |
Racecar Driver
1310
Rep 1,986
Drives: BMW M4
HotRodM4691.50 |
04-12-2024, 12:42 PM | #5 |
Rep 1,035
Drives: BMW X5M, M3 ZCP, MB E63 AMG
But that doesn't always mean that the reservoir has an issue. It could be coolant hoses as well, so those would be to check also. I would trace all the hoses the run to the intercooler and it's heat exchanger, just to be sure.
It is never taken for granted that a commitment to speed and acceleration must be matched with an equivalent ambition when it comes time to stop!
