04-24-2024, 09:57 AM | #2 |
Rep 3,994
M3 front shock diameter is larger, but some coilover use a spacer, if it's the type that can be removed, then the shock might be able to be used on a non-m. Be aware, some coilovers the spacer is welded and can't be removed, so needs to be taken on a case by case basis.
But the rear shocks are different, in order to use an M3 rear shock, Rear M3 Lower control arms are needed.
04-24-2024, 12:10 PM | #3 |
Rep 5,814
Are you having trouble finding suspension setups for the e9x non-M? As tdott stated the front strut diameters are different and removing the M strut adapter, doesn’t mean the M strut without adapter will fit on an e9x non-m. Also, as he correctly stated, the rear M damper is not a direct bolt-on for an e9x non-M.
What are you looking to do with the upgraded suspension; e.g., improved track performance, dual street-track use, increased street performance, etc.? What’s your approximate budget? |
04-25-2024, 11:49 AM | #5 |
Rep 488
Drives: 2009 E93 M3 DCT
