05-16-2024, 03:11 PM | #1 |
Cruising the Green Hell
116
Rep 99
2023 BMW M240i xDrive (ZTK)
Apex Wheels - VS-5RS in Motorsport Gold Front: 19x9" ET25 Rear: 19x10" ET38 Michelin Pilot Sport 4S Front: 255/35-19 Rear: 285/30-19 Other related bits: - 12mm H&R Spacers (All 4) *would recommend 10mm on the rear with these wheels… it’s stupid close to contact when under full compression - Dähler Sport Springs: Front Lowering: 25 mm/1.0″ Rear Lowering: 20 mm/0.8″ |
10
JoeyJoeJo231.00 aguycalleddb534.00 Red_sir182.50 VegasG42795.00 Fr3sh_BGMlite0.00 NoDramaG4263.00 BmwIowa251.00 Mario68128.00 inTgr8r2461.00 D3LTACHARL1331.50 |
05-16-2024, 08:13 PM | #2 |
Rep 519
Front: 255/35-19
Rear: 285/30-19 Any concerns with the 1.2% difference? Generally you don’t want to exceed 1% front and rear diameter for X-Drive…
2017 Chevrolet Corvette
2023 BMW M240i xDrive |
05-17-2024, 04:31 PM | #3 | |
116
Rep 99
ApexWheels considers it an xDrive compatatible fitment… and tbh that was enough for me so I could get use out of my factory 255. 🤪 Next time around I’ll opt for 255/40 out front to be closer to exact. |
Coconut821.50 |
05-17-2024, 08:51 PM | #4 |
Rep 973
Looks great !
Question about the BMW center caps on the Apex wheels - Was this an option from Apex to have the wheels accept BMW center caps ? Did you order BMW center caps, or did you use the caps from your OEM wheels ? |
07-09-2024, 09:47 PM | #6 |
Rep 75
@[BabyM240i] Love your aggressive fitment with the 12mm spacer. Currently I have ordered a set of 19x9.5 et20. This offset is pretty close to your rear 19x10 et 26 (38-12mm).
I am only concerned about the 35 series tire in the rear as its a little taller that yours. Would you say, the width or height of the tirewall is a greater influence in causing possible rubbing? |
07-09-2024, 10:33 PM | #7 |
Rep 40
Would 19x9.5 +23 with a 265/35 squared fit well flush or would be to aggressive past the fenders on non ztk g42. Thanks
07-10-2024, 01:11 AM | #8 | |
116
Rep 99
Next time around I’m going to get 255/40/19 to make sure I don’t piss off xDrive. I don’t think that will be an issue. On the rear tho… any taller or wider with the 12mm spacers would be concerning. The tire is as close as a business card away from the inside of the fender during full compression on the right rear especially. If I ever buy a slightly different tire or brand I’d consider getting a 10mm spacer on the rear. |
07-10-2024, 07:42 PM | #9 | |
Rep 75
Apex allows for 19x9.5 +25 with that exact tire, and it looks pretty good. example 1 https://g87.bimmerpost.com/forums/sh....php?t=1978825 example 2 https://g87.bimmerpost.com/forums/sh....php?t=1985999 Now regarding non-ZTK, thats a tough call. I believe the ZTX over-fenders provide 5mm of extra coverage. You'll have to review the pics in the second example and add your own 2 cents. Bear in mind, I am non-ZTK and will most likely settle on +20 offset. |
07-10-2024, 07:48 PM | #10 | |
Rep 75
Right now, i am basically where you are with the 12mm, AND ill have a taller 35 sidewall vs your 30....AND i am 5mm lower than your Dähler Sport springs in the rear... I might be screwed here... |
11-11-2024, 07:18 PM | #13 | |
Rep 6
19x9” front & 19x10” rear I don't have the fender liners (I think u guys call it ZTK) like u do. So I understand correctly at the front some 255/40 and the rear what do u put? |
11-19-2024, 05:34 PM | #14 |
Enthusiast
326
Rep 312
Drives: 2022 230i M Sport
BabyM240i...I am wanting to put BBS FS in 19x9 with 25 ET (squared). I see you have the same wheel size, but use spacers.
Were there fitment issues without the spacers? |
