04-14-2008, 03:43 PM | #1 |
Rep 4
free clutch modification (CDV)
hi everyone, i just ordered a 135 and have been surfing around for good modifications to reduce the 0-60. i want to try to compete with corvettes! anyway i found this modification called a clutch delay valve removal on another forum. it is free to do, has anyone tried it? here is the info i found. is this safe to do? does it help 0-60? >>>>>>>>>>>>>>>Tired of paying $30 plus for something you can do for free? I picked up a spare CDV from the wholesale department at my dealer for $5.95. You can also take out the CDV, modify it and replace it for FREE but I wanted to do everything at once while under the car so I spent $5.95 on a spare. I then took the following steps to modify the CDV. Before removal first crimp the rubber line leading to the CDV so you don't lose all you brake fluid. Here's a picture of the CDV before the modification. As you can see the fluid is restricted from flowing through quickly and will therefore slow the engagement of the clutch on fast shifts. Next take a small allen wrench and insert it into the small end of the CDV as shown. With minimal pressure tap the allen wrench and the restrictor will pop right out. Pictured here is the inside of the CDV once popped out. There is nothing else left inside the CDV and it's now guts free. Reinstall the modified CDV. Fluid is now free to flow through the valve unobstructed and you will notice the difference right away. If you reinstall the CDV quickly enough you may not need to bleed the lines but it's a good idea anyway. Since I did this mod months ago I don't have actual step-by-step instructions on how to do it but following is a link to the best DIY CDV replacement I've seen: http://www.billswebspace.com/BMWCDVMod.htm. Without the guts in your stock CDV it looks identical inside to the Zeckhausen modified CDV in this DIY.
04-14-2008, 04:05 PM | #4 |
Mein Führer! I can walk!
45
Rep 822
04-14-2008, 04:57 PM | #5 |
Rep 1,075
Do you happen to have the bmw part number for that fitting? Having one to modify before you tear into the car sounds like a very good idea. thanks
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
04-14-2008, 06:28 PM | #6 |
Car'a'carn
473
Rep 751
wow this is great.. too bad for all those guys that spent $30 on the mod
04-14-2008, 08:01 PM | #7 |
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
that's cool!!! So it's only a $6 part from the dealer? I may just pick one up and modify it. We were talking in another thread about drilling the thing out, but this is even better!!!!!!
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
04-15-2008, 01:15 AM | #10 |
Rep 119
I've done this too and it works.
1Hot135 did you previously own an R32?? EDIT: Just checked your site some more. Loved your R32 and fitted the rear triangulated brace to my Golf after seeing yours! 1-series walks all over the Golf I don't miss it.
04-15-2008, 10:03 PM | #12 |
Rep 309
WOW that is awesome!
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car 1989 Honda Civic Si-R Current Project 2002 Corolla CE Daily Driver www.TheTunerSource.com |
04-16-2008, 02:20 PM | #15 |
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
i also just confirmed part number with parts counter guru Colin B @ savage BMW:
21-52-6-764-872 $8.30 this is an awesome post by the OP! these restricters are like the ones installed in the shower head units, i normally always popped those out for higher water flow, never thought this cdv was built the same way... |
04-28-2008, 05:42 PM | #16 |
Rep 252
i just received my CDV in the mail. and i popped out the restricter with an allen wrench. worked just like he said it would. it took more force than i thought it would to pop out the middle piece. great mod. thanks for the heads up.
Titanium Silver
6 speed man Black Boston Leather Gray Poplar Trim Nav system Comfort access Power/Heated seats Sattelite radio Ipod Production number 398**** |
04-28-2008, 07:01 PM | #17 |
Rep 1,657
i've read you should bleed the clutch when installing this.
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
04-29-2008, 04:07 AM | #18 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Will engagement be even further improved by enlarging the hole?
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason |
04-29-2008, 08:02 AM | #19 |
Rep 7,594
Drives: '19 M2C
I have my modified CDV, but I still haven't had time to replace it.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
05-13-2008, 10:22 AM | #21 |
Rep 7,594
Drives: '19 M2C
My local dealership.
