      04-17-2008, 10:34 AM   #1
AndyM
AndyM's Avatar
134
Drives:
Let's remove/install the Kidney Grills
Tools Required
T-30 Torx Driver
Right Angle Tool
Flashlight
Flat Blade Screwdriver
Removing the Kidney Grills
With the hood open, begin by removing the 4 T-30 Screws above the kidney grills and set them aside.
You will also want to lift the strip of insulation at the front of the hood off of it’s sleeve. You remove it by pulling up.
The Kidney Grills are held in with 6 clips. There are three along the top edge, one along the side toward the light and two along the bottom. If you are replacing the Kidney Grills, look at the new Grills: you will see the locations of the clips. To remove the kidney grills, you need to lift the two clips along the bottom of the grills. The easiest way to do this is with a right angle tool. They are available from Sears and are a handy tool to have. Sears part number: 00999802000 ($12.99). Sears carries a few different varieties.
You will want to begin by undocking the two lower clips. You will be able to see them in between the slats in the grill. You may need a flashlight to help you locate them. Once you have located them, insert the right angle tool to lift the center section of the clip and lift up. You will want to use your free hand to gently pull the grill toward you. You will want to prevent the grill from re-docking itself so once you have one side unclipped, keep enough pressure outward so it does not go back in.
With the lower clips undocked, you can begin working on the upper clips. In order to access the clips, you want to pull up on the bumper trim and if you look in from the engine compartment, you will see the three clips. Use a flat blade screwdriver or the pointed end of the pick to push the clips down.
As you did with the lower clips, gently pull the grill toward you to keep the clips from re-engaging. Once you have the 3 upper clips undocked, you can pull the grills out.
Installing the new Kidney Grills
To install the new grills, simply line them up and push them in until you hear the clips engage. Once you have both grills installed, replace the 4 T-30 Screws and tighten them down. Re-install the strip of insulation.
If you follow this DIY , please post a thank you.
      04-17-2008, 12:01 PM   #2
Templedogg
Drives: 135i, Trailblazer SS, 1934 PU
Great DIY! Thanks.
      04-20-2008, 01:08 PM   #3
SlickShift
SlickShift's Avatar
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
Thanks for the DIY. I was wondering what "right-angled tools" everyone was using.
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      04-27-2008, 02:30 AM   #4
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Thank you very much for this DIY. Today, I ordered a set of 128 nostrils/kidneys, I see the black grill bars as far more attractive on a black car than the stock 135 item which has chrome grill bars.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      04-27-2008, 03:19 AM   #5
Oregon
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
The parts should arrive at the dealer late next week, weekend install, pics Saturday evening?
      04-27-2008, 07:04 AM   #6
AndyM
AndyM's Avatar
134
Drives:
I did this on my Montego 135. The shadowline/tii grills were too black and the 135 grills were too chrome. I like the 128 grills quite a bit better than either.
      04-27-2008, 07:59 AM   #7
Chop79
Drives:
2008 135i  [0.00]
I think the chrome grills look much better. The shadow grills almost look like nothing is there. IMO IMO IMO:wink:
2008 135i
Alpine White, Black'ette/High Gloss, Sport, CA, Heated Seats, iPod Adaptor, Premium hifi, Sirius, BMW Assist
      04-27-2008, 10:35 PM   #8
One&Only
Only 1 n Rome
One&Only's Avatar
Drives: '08 135i Coupe
need a PIX really bad....dunno what i want unless I see sumpin pleeeeezzzz! Dark kidney's will look deadly on my car...but what shade of dark:iono:
Drives a Sawed-Off Shotgun
135i/SGM/Terra/Gray Poplar/Sport Pac/H&R Sport Springs & Sways/Heated Seats/Premium HI-FI/Sat
      04-27-2008, 11:14 PM   #9
hitthemark41
Drives:
Just curious about the 128s...are they still chrome trimmed? I have a 135 BSM (obvious by my sig sorry lol) on order...and am looking for "the look"......just afraid the shadowline might be TOO dark for the sapphire metallic. Thanks for any info/opinions anyone has!
2008 (Year 1 of the One ) 135i
Black Sapphire Metallic/Savanna Beige/
Gray Poplar/6MT/Sports & Premium pkgs/CA/Heated Seats/HD/PDC
Mods:35% tint / clear bra / Perf. pedals
      04-27-2008, 11:36 PM   #10
Oregon
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
128 kidneys have the chrome surround with black grill bars, as my 135 is JB, I thought the 128 kidneys would be more aesthetically pleasing, it plain looks better without chrome grill bars, at least, to me, plus, it's my car. Ha, ha...:biggrin:
      04-29-2008, 02:21 PM   #11
AndyM
AndyM's Avatar
134
Drives:
Here is a comparison between the 3 available kidney grills.
128 Kidney Grills (Chrome with black vertical slats):
135 Kidney Grills (Chrome with chrome vertical slats):
Shadowline/Tii Kidney Grills (Black with black vertical slats):
      04-29-2008, 02:50 PM   #12
Oregon
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Hey Andy, thanks for the presentation. 128 kidneys definitely for me.:wink:
      04-29-2008, 02:53 PM   #13
AndyM
AndyM's Avatar
134
Drives:
Same here. :w00t:
I lasted 1 day with the shadowline and they were too black for me.
I will look and see if I have a pic from the same angle with the 135 grills.
      04-29-2008, 03:01 PM   #14
hitthemark41
Drives:
Originally Posted by AndyM View Post
Same here. :w00t:
what color do you have Andy? I have a BSM on order and am afraid the Shadowline will be TOO dark for that shade of black. Do you guys order the 128s from the dealer or somewhere else? Thanks!
duh...guessing that is YOUR montego in the pics? if so...sorry for the dumb question haha
      04-29-2008, 03:15 PM   #15
AndyM
AndyM's Avatar
134
Drives:
Yeah, my car is Montego, no worries :wink:.
I liked the shadowline grills when they were installed until I saw the car from across a parking lot. It looked like someone forgot to put them in. I thought the 135 grills were too much chrome for a car with no chrome on it so the 128 grills were the way to go.
Tischer is probably your best bet for the 128 grills. The 128 and 135 grills are much cheaper than the shadowline ones. You pay for the white box with “BMW Performance” printed on it.
      04-29-2008, 03:17 PM   #16
Vidge
Drives:
Any one fancy selling their crome grills? as i prefer them with sedona, on my 123d i have the 128 grills.
123d M sport, Sedona Red, Boston Black Leather, 261s, Xenons, Bluetooth, USB, Brushed Aluminium, Darkened Glass, Cruise Control.
      04-29-2008, 03:22 PM   #17
TP 135i
TP 135i's Avatar
Drives: 2008 135i SGM MT
Just playin around...I switched mine yestersday to the Shadowline perimeter with the OEM chrome tipped interior slats.
It presents a nice combination....not a completely "blacked-out" look and eliminates the big chrome frame.
2008 135i SGM
      04-29-2008, 06:18 PM   #18
hitthemark41
Drives:
yeah I might be willing to sell my chrome grills if and when I switch to another set...but I dont expect to take delivery of my 135i until July, so not sure if that is soon enough. Hope that helps, and thanks again Andy for the tip
p.s. Tischer?
      04-30-2008, 09:33 PM   #19
OzF16
BMF
Drives:
Do you have a picture? This is the one combo I haven't seen.
135i
SGM, Coral Red Leather, Gray Poplar Trim, 6MT, Sport pkg, Premium pkg, Cold Wx pkg, Comfort Access, Premium Hi-Fi, Satellite Radio
Delivered May 12th!
      05-01-2008, 05:54 AM   #20
TP 135i
TP 135i's Avatar
Your wish is my command...........Shadowline frames with OEM interior grille bars.
2008 135i SGM
      05-01-2008, 06:48 AM   #21
essexcounty
Drives:
^ TP, that looks very fly...real nice touch.
      05-01-2008, 03:26 PM   #22
malves85
Drives:
Very cool! I got my shadowline grill at home with the car still on the way. I might have to take your idea and interchange the grills to look like that. Next you have to put the chrome lip and black grill. Change it up every month to mess with people:-P Its good to know you can switch the grills easily. Thanks AndyM for the DIY and TP 135i for the pics!
1addicts
