      05-23-2024, 02:54 PM   #1
mpfardresher
Drives: 2024 G87 M2
Light click at final release point of the clutch
I have had the car for two weeks less then 400 miles and I started to hear a light 'click' sound only the final point the clutch pedal is released. And it sounds like its coming from inside the car, near the pedal. This happens with the car on or off. And I only really hear it when the clutch is let out slowly. I took the car in to the dealership to have them take a look. They confirmed that the 'click' is there but its not creating any feedback to the pedal nor does it cause any performance issues. In less then 1,000 miles I need to bring the car back for the break-in check up. So they ask just to monitor it and if no change they will take a deeper look at it at that point. Was wondering if anyone has heard of this happing or had this happen? Maybe the car/clutch still needs to get broken in and that's all?
      05-23-2024, 03:10 PM   #2
dissident111
dissident111's Avatar
Drives: 2024 M2
Just hit 1000 miles on mine and never hear any sound like that from clutch.
      05-23-2024, 03:16 PM   #3
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
It sounds like you’re having a similar issue to that of which MineralGreyMetallic is having with his G87.
Sounds like a minor loose spring issue. I’d get it checked regardless even if they say it’s a non issue.
This should not be happening and is not normal for the car, even during the clutch break process.
      05-23-2024, 03:20 PM   #4
mpfardresher
Drives: 2024 G87 M2
When I take it back they said they are going to pull the panel and take a deeper dive. Hope its a simple loose spring.
Geighty72730.00
      05-23-2024, 04:16 PM   #5
mpfardresher
Drives: 2024 G87 M2
Do you know if it was just a spring for MGM, that was the problem?
      05-23-2024, 05:02 PM   #6
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
I think he has yet to take it in or awaiting it currently.
      05-28-2024, 08:37 AM   #7
MineralGreyMetallic
MineralGreyMetallic's Avatar
1100
Drives: 24 BGM M2 6MT
Yes sir, same exact issue. The slower the release, the louder the clicking. It started happening somewhere before 1,000 miles. At about 1,500 miles now it does not seem to be getting better or worse.
I need to reschedule my appointment with the dealership to leave it there for a few days, which is what they requested.
I've seen threads in other forums for other BMW models where people have experienced similar issues.
If you get it diagnosed or fixed please keep us updated! I'll do the same.
Here's the thread I started previously: https://g87.bimmerpost.com/forums/sh....php?t=2094764
      05-28-2024, 12:15 PM   #8
mpfardresher
Drives: 2024 G87 M2
When I take it in for the 1,200 mile break in (in about 900 miles), they said they will take a deeper dive and take off the panel. When I look under at the clutch peddle it looks like its a small "accordion" like part when fully extended it makes the 'click' sound. I will absolutely come back here and post what they find.
      06-01-2024, 10:46 PM   #9
infinityomega
Drives: g87 m2
I’m having the same issue, any update? I’m taking mine in Monday for its break in appointment and will see what they say.
      06-02-2024, 07:21 PM   #10
mpfardresher
Drives: 2024 G87 M2
I’m still waiting to hit the 1,200 mile break in, so no update. But please come back and let me know what they say about yours.
      06-04-2024, 10:36 AM   #11
infinityomega
Drives: g87 m2
Update: Had a few members look at it and said it’s the sensor telling the car the clutch is engaged and it’s normal to make the slight click. I’ll note if it gets worse but everything is functioning as it should.
      06-04-2024, 11:20 AM   #12
MineralGreyMetallic
1100
That doesn't sound right.
I don't just get a single click. I often get multiple clicks that vary in volume and are not consistent across engagements of the clutch. It very much sounds like a mechanical component being stressed or de-stressed, like a spring.
At this point it might be helpful to start getting some recordings to be sure we're all experiencing the same thing.
      06-07-2024, 02:03 PM   #13
mpfardresher
Drives: 2024 G87 M2
here is the click I am getting at the end of the release....are you getting the same thing?
https://www.youtube.com/shorts/lSjDvcqpUYM
      06-07-2024, 02:56 PM   #14
BroDoze
Drives: 2025 M2 LCI
That's pretty annoying sounding.
///M
      06-08-2024, 09:35 AM   #15
MineralGreyMetallic
1100
Thanks for posting that mpfardresher
Pretty much what I'm hearing, although mine is a little higher frequency. Probably just the phone's mic changing the sound of it on the recording.
I'll try to get a video in the next couple days.
Normally this type of thing drives me absolutely crazy. Seeing that it's way more common than I would have expected makes it bother me less.
      06-08-2024, 11:27 AM   #16
mpfardresher
Drives: 2024 G87 M2
I am right there with you. I will add (to your point) the mic on the phone makes it sound a lot louder and bit different then what it actually sounds like. I will still have them take a deeper look into it when i take it in for my break-in check. But honestly its not that bad and like you knowing that its common, really doesn't bug me as much
      06-08-2024, 01:02 PM   #17
Geighty7
Geighty7's Avatar
Drives: 2024 BMW M2
Nah take that in that’s extremely annoying for an M car. Tell them to throw in a free service or something for the inconvenience of not detecting this on PDI.
      06-08-2024, 01:10 PM   #18
MineralGreyMetallic
1100
To be fair, it was not happening on delivery in my case. It only developed a few hundred miles later. You are right, though. Not an acceptable thing to be happening on really any car.
      06-09-2024, 08:20 PM   #19
mpfardresher
Drives: 2024 G87 M2
Mine was the same, 400 miles and it started
      06-26-2024, 01:14 PM   #20
Dirtywabbit
Drives: M2 G87
My brand new m2 has a creak thru the middle release and then the click at the 90% release of the pedal.
Pretty annoying.
      06-26-2024, 02:08 PM   #21
MineralGreyMetallic
1100
Pretty annoying.
Welcome to the club. Sorry to hear it.
If you manage to get it diagnosed/fixed, please report back. The cause is still unknown.
      06-26-2024, 06:58 PM   #22
mpfardresher
Drives: 2024 G87 M2
Pretty annoying.
I have my break in service this Friday and they are gong to take a deep dive into it. Ill reply back with what they say.
