      05-16-2008, 04:32 PM   #1
AndyM
AndyM's Avatar
134
Drives:
Let's install the Grocery Grabber
Tools Required:
-5/16“ or 8mm Drill bit and drill
-Drill Bit Collar
-Phillips Screwdriver
-Center Punch and hammer
-Masking Tape
Installation of the Grocery Grabber
BMW supplies a very nice installation manual for the Grocery Grabber. Surprisingly nice as it is not Ikea-style drawings as BMW usually does but actually has notes to go along with the pretty pictures.
The Grocery Grabber Contents:
You also need the supplementary Installation kit:
The kit comes with a template to mark where the holes will go:
Cut out the trunk light location as well as the leading edge of the sheet metal as indicated on the template. The side shown will mount the Grabber on the passenger side of the trunk. If installing on the driver side, you will need to flip the template.
Use some masking tape to tape the template to the trunk and mark the holes with the center punch. With the location of the holes marked, drill the 5/16” holes. Important: Do not let the drill exceed 5mm as it can damage the car. I used a Drill Bit Collar set to 5mm to make sure I did not go beyond 5mm when drilling. Note: You will want to lay some old towels or a drop cloth in the trunk area prior to drilling. Sheet metal shavings are tough to get out of carpet.
With the holes drilled, insert the supplied well nuts into the holes. You will now mount the mounting studs. The hardware layout is as follows:
The Mounting Studs installed:
With the Mounting Studs installed, install the Grocery Grabber and use the plugs to cover the screw holes.
      05-16-2008, 04:35 PM   #2
tjockey
Drives:
Who the hell can afford groceries...:biggrin:
      05-16-2008, 04:41 PM   #3
AndyM
AndyM's Avatar
134
Drives:
I need to keep the beer from rolling around in the trunk on those hard turns coming home from the store!
      05-17-2008, 07:41 PM   #4
FreeBMW.net
Drives: 2008 BMW 135i
Interesting....my car has one of these installed already??!!
      05-19-2008, 02:22 PM   #5
Sherifftruman
Drives:
So, is this something to loop the handles of plastic bags over so they don;t slide around?
      05-19-2008, 04:36 PM   #6
AndyM
AndyM's Avatar
134
Drives:
Do you have the premium package?
That is exactly what it is for.
      05-19-2008, 05:13 PM   #7
FreeBMW.net
Yep, i do
      06-13-2008, 09:37 AM   #8
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Bump to find out if ANYBODY else has these installed from the factory. I have the Premium Package, and do not have this, as Clayton does.
      06-13-2008, 10:15 AM   #9
AchtungF80
AchtungF80's Avatar
Philippines
276
Drives: 997.2 GT3, '17 G30
2008 135is  [9.50]
2010 Cooper S  [10.00]
1991 318is  [10.00]
Cool accessory but who risks their 1er at the grocery store with all those shopping carts and inconsiderate minivan/SUV owners :wink:
ig: 0verrev
      06-17-2008, 09:33 AM   #10
bman6074
Drives: 14 M235i and 07 Lotus Exige S
WOW why is this Grocery Bag Grabber so expensive? 30 dollars for a few pieces of platic
      06-25-2008, 12:22 AM   #11
runNgun
runNgun's Avatar
Drives:
Just went out to check and mine doesn't have it.
      06-25-2008, 05:34 AM   #12
AussieRacer
AussieRacer's Avatar
Australia
24
Drives: 2008 135i
Does the grocery grabber reduce the loading height, meaning bigger boxes don't fit? If so, by how much?
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
      07-01-2008, 11:05 AM   #13
rwp120
Drives: AW 135i
2008 135i  [0.00]
Dealership charged me $130 to install this. After seeing how easy it was I really regret not doing it myself!
      08-02-2008, 06:44 PM   #14
topvega
Kinda sorta banned on N54
topvega's Avatar
Drives: 135 SGM JB3
Holy Crap!!! What a rip....they shld be ashamed to charge that much for this....it's barely any labor at all and totally a DIY job... that sucks
      08-02-2008, 08:56 PM   #15
rwp120
Drives: AW 135i
2008 135i  [0.00]
What's worse than that is how they charged me $125 to install each of the CF mirror caps! That's $250 to just snap them right on!
      11-10-2008, 08:30 AM   #16
lambammm
Drives: 2009 135i montego/coral
Wow Hawaiians must have money to burn. I'd say you found the DIY section a couple hundred dollars too late.
      08-09-2010, 03:12 PM   #17
doogle
doogle's Avatar
Drives: 335i
Serious post, you can hook a small bungee cord to the hooks closest to the rear bumper and hold 2 glass 6 packs.
      08-09-2010, 07:41 PM   #18
Evice
Evice's Avatar
194
Drives: E92M3
really 2 years later a reply ? lol.
      05-29-2012, 07:37 PM   #19
Wings0fRed
Newb
Wings0fRed's Avatar
Drives: 2008 135i
Let's make it another 2 years...Great post, thanks for the writeup!
Wings
      05-29-2012, 07:47 PM   #20
int2str
int2str's Avatar
Germany
80
Drives: 2008 135i
Part numbers seem to be:
82260153360 Bag holder (~$20 online)
82110306046 Mount kit (~$5 online)
      05-30-2012, 06:40 PM   #21
Mr. Clarkson
Mr. Clarkson's Avatar
41
Drives: 2011 135i
2011 135i  [0.00]
I installed the fold-away hooks from a 3-series in mine:
      05-30-2012, 07:10 PM   #22
int2str
int2str's Avatar
Germany
80
Drives: 2008 135i
Part number?
1addicts
