      05-19-2008, 10:07 PM   #1
NY SLC 93
NY SLC 93's Avatar
Drives: 135i
Question Can you install BMW Assist ?
Just picked up the 1er and I am regretting not getting BMW assist because I want to use the BT phone feature thru the navi.
Is it possible to have it installed?
      05-20-2008, 08:05 AM   #2
NY SLC 93
NY SLC 93's Avatar
Drives: 135i
Is there any extra button or controls in the car for the BMW Assist or is it all controlled thru the navi?
Does anyone have pics?
      05-20-2008, 09:15 AM   #3
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
There's a button under a cover, up in the overheard console, that initiates the Assist call. I believe Assist is not retrofittable, just as BT is not retrofittable.
      05-20-2008, 10:09 AM   #4
NJKSC27
automobile aficionado
111
Drives:
i bet if you REALLY know what your doing, it can be done
      05-20-2008, 10:58 AM   #5
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
Actually, I asked that question when I picked up my car yesterday. It can be retrofitted. But it would be expensive because it requires replacing the TCU.
AMS, Berk Technology, aFe, ER
      05-20-2008, 12:58 PM   #6
NY SLC 93
NY SLC 93's Avatar
Drives: 135i
Can you please elaborate? Cost, part numbers, instructions?
Thanks.
      05-20-2008, 01:26 PM   #7
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
Thanks.
Sorry no. I didn't ask about anything that specific.
      05-20-2008, 05:11 PM   #8
bimmertech
Drives:
if your car is equipped with telephone prewiring, you need a tcu and an fzd (the entire roof module that has both the sos button and the sunroof button), you also need a programming update.
      05-21-2008, 10:30 PM   #9
griptruk
Drives:
please take this for what it's worth, which is just a guess.
But if it's the bluetooth specifically that you want, and not the actual assist part of it, I think that would be easier to retrofit than the entire assist system. I am somewhat sure that you can order the bluetooth as a standalone option so it may be not that crazy to retrofit just the bluetooth.
2008 135i 6speed - euro delivery
      05-22-2008, 05:38 PM   #10
bimmertech
Drives:
you can do a bluetooth only retrofit which would add a ULF control module, in addition to some hardware and a bluetooth antenna. you would still need a programming update.
griptruk: wear are you getting your vehicle? i work at habberstad bmw...i know that we've done a couple of ED's here for the 1.
      06-30-2008, 11:34 AM   #11
NY SLC 93
NY SLC 93's Avatar
Drives: 135i
Can you please elborate? Do you know any part numbers and the associated costs? Is there tech bulletin on how to do this?
I just want to be able to use BT thru my navi and not void the warranty.
Thanks
      06-30-2008, 02:04 PM   #12
mastermav
Drives: '19 F82
I saw the post on e90post.com forum from the guy, who actually did retrofit his e90. He spent $1600. I do not think it is worth it.
      07-03-2008, 02:51 PM   #13
itsthechuck
Drives: 135, E34M, E30rally,S6, E30 M3
Just in case anyone was looking for the e90post it is located here http://www.e90post.com/forums/showthread.php?t=85149 I was hoping it would be a bit easier.
      07-04-2008, 02:24 PM   #14
hbiscuit
Drives: 2008 M3
I'd like to know if you could retrofit a switch to disable it... so the powers that be can't locate your cars whereabouts if you didn't want them to...
1addicts
