05-23-2008, 11:54 PM | #1 |
Rep 3,479
Drives: 19 M2C 6MT
Gp Thunder DIY please?
Hi, can someone do a GP Thunder h8 and h3 DYI? cause there coming in the mail, and i wanna put them on..=D thx to anyone that does...:thumbup:
05-24-2008, 02:07 AM | #3 |
Rep 2,012
really easy. Someone did it on here and has a DIY already. Do a search. If u can't find it with search, then look at larryn's old posts, he's the one that posted the DIY i think.
05-25-2008, 09:14 PM | #5 |
Rep 1,083
Instructions for daytime running lights is in your owner's manual. Put on some latex gloves so you don't cut up your hands, the latex gloves will be torn up when you're done. Start on the driver side because it's easier. The passenger side is a bitch but I have small hands so I didn't even need to take off the cover to squeeze in there. Good luck.
05-25-2008, 09:27 PM | #6 |
Rep 3,479
Drives: 19 M2C 6MT
lol i play basketball..and i can palm the ball.too big of hands? =D
05-25-2008, 10:56 PM | #7 |
Rep 226
The ears on the covers are the hardest to deal with on the passenger side. Just jiggle them in, don't force anything too hard and make sure those bitch clips don't break off. I would not like to try and find those in the engine bay.
05-25-2008, 11:16 PM | #8 |
Rep 4,311
Drives: Supercharged E90 M3
we need a step by step:
i get my car in like 3 days and i need to know how to do this.
05-26-2008, 06:52 AM | #9 |
Rep 10,176
No step by step needed. There's two spring clips on the back side of each headlight housing. Just pop those over to the side and take the cover off the back of the headlight. As mentioned, there's two plastic ears at the bottom of that cover that you need to take into account. The bulbs are obvious, and are removed by an 1/8 turn. Don't touch the lamps and unplug it, replace with the new bulb, and put it back together.
It's all pretty obvious, and the owner's manual does have instructions on how to change it too, as mentioned. |
05-26-2008, 07:39 AM | #10 |
Rep 437
05-29-2008, 08:39 AM | #11 | |
Rep 631
1. CAREFULLY slide off the 'Bitch' clips on each side of the headlight housing. 2. Wiggle the HL housing off - this is a bit of a pain 3. Twist the H3 bulb to unlock, and gently pull out 4. Use a small flat-head scredriver to gently remove the little gray clips on each side of the bulb; remove bulb 5. Carefully plug new bulb in. 6. Insert new bulb into housing, and twist to lock in place. - One side was a PITA to get it to lock - Make sure it's properly sealed 7. Reinstall HL covers - Make sure that the tabs are inserted in the holes at the bottom for a proper seal - This is also a PITA! Overall it's really easy, it's just a pain to wiggle the covers into place. Good luck! |
06-20-2008, 02:38 PM | #12 |
Rep 119
Just curious if anyone has replaced the h3 bulbs yet. I tried removing the top cover from the light housing as instructed in the owners manual, but ended up breaking the clip and still can't get the cover off. Any help with this would be greatly appreciated.
For clarification, the response written above this is applicable for the h8 bulbs unless I totally missed seeing the h3 bulb slot and the owners manual is written incorrectly. |
07-14-2008, 11:55 PM | #13 |
Rep 3,479
Drives: 19 M2C 6MT
Tommorow im putting the Gp Thunder LED ones in, so ill have some pics up of the difference and everything =D
07-19-2008, 05:27 PM | #14 |
Good life
130
Rep 1,937
Are you talking about the halo rings or interior LED? I'm ready to order some.
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
07-22-2008, 01:43 PM | #15 |
Rep 18
i'm trying to swap out my standard halogen h7 bulbs on my non xenon lights. i can get the covers off fine but there are clips holding the bulbs in that are very firm and really difficult to even see. any tips? thanks!
09-03-2008, 01:36 AM | #19 |
860
Rep 35,253
09-26-2008, 09:43 AM | #20 |
Rep 932
If you break the cornering light covers, guess what you can't buy new ones as BMW doesn't list them. Don't ask me how I know, and someone prove me wrong, Please!!
Fran |
11-27-2008, 05:58 PM | #21 |
Rep 1,118
Wow.. i actually had to shave a little bit off of the passenger sides covers ears to get it back in... i have never swore so much in my life trying to change bulbs on a car!
but yes it looks good now!
-----LS3 C6----- z51 suspension, NPP dual mode exhaust(wild2mild),20% tint, zr1 replica wheels, gloss black fender stripes R.I.P SGM 135i w/ some mods |
