10-20-2024, 12:22 PM | #1 |
![]() ![]() ![]() ![]() 2449
Rep 500
How we Built a 1500HP BMW S58 Engine: Step-by-Step Guide [R44 Performance]
![]() Featured on BIMMERPOST.com Hi everyone. For those who don’t know, R44 Performance is currently building a G87 M2 xDrive drag car in partnership with Tom Wrigley Performance due to be shipped over to the US very soon for Texas 2K25 and a number of other events. The goal is to achieve a 1:1 power-to-weight ratio with upwards of 1500bhp & 1500 kg. Of course, achieving this level of power required building the S58 engine with a range of upgraded internals. There are lots of big power S58s out there and we wanted to share the exact parts & setup we’re running to maintain reliability with such high performance. If you’re into engineering, this post is definitely for you! PART 1: PART 2: A lot of people have asked us “Do you mean 1500 wheel-horsepower or 1500 bhp?”. The honest answer is: we’re not quite sure yet. The built engine will be capable of around 1800 bhp and the car is yet to be tuned and dialed in. We’ll be detailing the exact power and weight figures very soon! For the latest updates on the project, check out the build thread here: https://g87.bimmerpost.com/forums/sh....php?t=2104190 ISN’T THE BMW S58 ENGINE FORGED FROM FACTORY? Although the main internal components - crankshaft, pistons, conrods, camshafts - are already forged from the factory, forging is just a manufacturing process. Design & materials also play a huge role when it comes to strength. In order to achieve this level of power reliably, the majority of the engine internals need to be upgraded with stronger components. WHAT ENGINE HARDWARE NEEDS TO BE UPGRADED? To make things simple, here is a list of all the internals our S58 is running:
ARP STUDS We used ARP studs on our previous 1,000 bhp G80 M3 build and they’ll be essential for our G87 project. The studs will allow a higher clamping pressure and improve stability and strength. The OEM bolts can move around a bit which puts wear on the bearings and increases the chance of failure. PRO-XTREME PISTONS & RODS These components are manufactured by Carrillo but built to 5150 AutoSport’s specifications. The rods take an unbelievable amount of strain, which is why upgrading to a thicker forged steel rod is essential. The pistons are forged aluminum with a different strength-promoting design, as shown in the side-by-side comparison. XTREME DUTY CYLINDER SLEEVES & O-RINGS To increase the strength of the block itself, we’re using heavy-duty cylinder sleeves, also from 5150 AutoSport. Installing these required machining, courtesy of SpecJ Motorsport here in the UK. The O-rings that accompany the sleeves pinch the head gasket to the head, allowing us to run high levels of boost without any lift. GSC BILLET STAGE 2 CAMSHAFTS These BMW S58 upgraded camshafts from GSC are works of art. In addition to looking amazing, these camshafts are incredibly strong, as proven on Tom Wrigley’s 1500 bhp G80 M3. In addition to being stronger, the GSC stage 2 cams have larger lobes which cause the valves to open further and for longer. The stage 3 camshafts have an even larger lobe duration however, they are largely untested at the moment which is why we’re sticking with the tried and tested S2’s for now. GSC UPRATED VALVES In addition to the camshafts, GSC also supplied us with their super alloy valves. Just like the other components, the valves are incredibly strong to ensure the setup copes with high levels of boost and an increased redline. The most notable difference is the design of the head which is also swirl-polished. This increases airflow by 30CFM over the standard valves. All benefits include:
GSC BEEHIVE VALVE SPRINGS To support the valves, we’re running GSC’s oval valve springs with titanium retainers. The ‘beehive’ design means the coils are progressive in size, increasing strength. They also utilize advanced material heat treatment methods for superior load loss capabilities. These springs have the highest level of spring load retention while still maintaining good fatigue throughout the life of the spring. Beehive springs allow for the use of a smaller, lighter retainer allowing for higher RPM and more valve control. Valve specifications: Max RPM: 9,000 RPM Max boost: 70 psi 101 lbs @ 1.415" install height 221lbs @ 0.982" (11mm Valve Lift) Their primary function is to prevent what’s known as valve float. This is where high levels of boost cause the valves to push open as the spring doesn’t have enough resistance. GSC VALVE STEM SEALS Lastly, GSC Power-Division Viton® valve seals provide improved resistance to high temperatures, fuel, and chemical contaminants as well as extended wear as seen in high rpm engines. These are the last pieces to the puzzle and round up the engine hardware we’re using to achieve over 1500 bhp in our BMW G87 M2’s S58 engine. We’re aware that, for those who aren’t deep within the BMW tuning community, finding a reliable source of both engine parts and advice can be difficult. R44 Performance is now an authorized supplier of all the engine components listed above and much more. If you require any help or advice about which components would be best for your application, get in touch with our sales team: https://r44performance.com/pages/contact 5150 AutoSport: https://r44performance.com/collections/5150-autosport GSC Power-Division: https://r44performance.com/collectio...n-engine-parts Last edited by R44 Performance; 10-21-2024 at 11:02 AM.. |
37
71dsp114.00 e92_enthusiast_1122.50 NewToM1832.00 aerobod4516.00 MA-Motors0.00 rotatingchicken40.50 maverick618426.00 EL Jeffe 5643.50 LateParty2018X535d95.00 BroDoze2693.00 F22Dean0.00 DocWeatherington3558.00 Spaxe25.50 ra2289326.50 ednir981324.50 agentrnge404.00 forcefed3877.50 Jimc44.00 Consuldean89.00 Mad_Moose16.00 apez851.00 cfm56d7b6846.00 ledphut1053.50 SCD-1983642.50 daddyjaxx125.50 thereef5102002.00 werdn731.00 jpf34016.50 M Division1253.50 Tenac4845.00 Click_ID831.00 cdn240cab45.00 KB7152.50 2srsman97.50 dancing__narwhal202.50 Sinister84057.00 hk2357.50 |
10-20-2024, 02:59 PM | #2 |
Car'a'carn
800
Rep 1,212
Wow I saw one video but I'll have to watch the other videos later.
Springs are rated to 9000. Does the engine rev to that? |
10-21-2024, 01:19 AM | #3 |
Rep 500
12
rotatingchicken40.50 RoGo330i177.00 BroDoze2693.00 mrdudley641.50 daddyjaxx125.50 werdn731.00 MaC-N54-E82631.50 Click_ID831.00 antzcrashing1956.00 2srsman97.50 dancing__narwhal202.50 VR11002.00 |
10-21-2024, 07:51 AM | #4 |
![]() ![]() 95
Rep 149
Drives: F15 - 2018 BMW X5 35d - Stock
HOT DAM 🔥 1:1 Ratio, 1500bhp , now that is some TEXAS sized power right there cowboy
10-21-2024, 07:56 AM | #5 |
Rep 2
Thank you for the detailed post. Truly interesting
I will definitely take time to watch the serie |
R44 Performance2449.00 GhostRider1240.00 |
10-21-2024, 08:05 AM | #6 |
Rep 10
This is awesome.
R44 Performance2449.00 dancing__narwhal202.50 |
10-21-2024, 08:20 AM | #7 |
![]() ![]() 3558
Rep 4,565
Awesome post, looking forward to the final versions
10-21-2024, 08:29 AM | #8 | |
Rep 81
This post is why this forum is the BMW heaven of the internet. Bless, thank you 🫡 Last edited by LuckyL; 10-21-2024 at 08:30 AM.. |
10-21-2024, 08:41 AM | #9 |
![]() ![]() 965
Rep 330
Drives: 2023 BMW M4 Competition
Can’t wait to see this. Thanks for the effort put forth to share with the forum.
IG @Oandmcraftworks
IG @Ownerf16 |
R44 Performance2449.00 |
10-21-2024, 09:49 AM | #10 |
![]() ![]() 152
Rep 53
Drives: 2018 M3 Competition
A master piece! 🔥
10-21-2024, 10:24 AM | #11 |
Joint Chiefs of Staff
![]() ![]() 29084
Rep 199,511
Sick!
https://x-ph.com/sale/ Phone number 702-494-9435 ![]() |
10-21-2024, 10:33 AM | #12 |
![]() 83
Rep 110
Believe there is a typo in the material of the rods. Those pictures are not aluminum rods.
10-21-2024, 11:04 AM | #13 |
Rep 500
10-21-2024, 11:05 AM | #14 |
Rep 500
10-21-2024, 11:06 AM | #15 |
Rep 500
10-21-2024, 12:04 PM | #16 |
![]() ![]() 4687
Rep 1,754
Drives: 2022 X5 m50i
Great project. Love it when engineering is pushing limits.
25 G70 760i Msport
25 RR SV E2 RETIRED BMWs: '23 F92 M8 Comp / '22 G05 X5 m50i / '18 F15 X5 50i / '16 F10 550xi / '13 BMW F10 535i / '07 E64 630i / '03 E65 745i / '95 E34 540i / '89 E30 M3 Last edited by hufington; 10-21-2024 at 12:23 PM.. |
R44 Performance2449.00 orkinos317.00 |
10-21-2024, 12:59 PM | #17 |
![]() ![]() ![]() ![]() 6846
Rep 11,063
I want this engine. Even if it means displaying this engine in my office as an art piece. These “truth in engineering” projects are invaluable.
PS. Acknowledging Audi’s “truth in engineering” slogan. |
10-21-2024, 07:28 PM | #18 |
![]() 130
Rep 83
Drives: 12' 328i,17' 340I, EQE 350 SUV
Thanks for sharing, what an awesome build!
Hoping to see the S58 venture into the 2,000 HP mark one of these days, who knows maybe you guys will be the ones to do it! |
BradMX5871.00 R44 Performance2449.00 |
10-21-2024, 08:15 PM | #19 |
![]() 1971
Rep 1,965
Soon we will need a Billet block
10-22-2024, 12:24 AM | #20 |
S58 Love
![]() 632
Rep 494
Drives: 2023 M4 Competition xDrive
So much good in this build. Thanks for pushing what’s possible on this platform.
MAC
Current: 2023 G82|BG over BLK Prior: 2008 N54 E82|AW over CR Also: FJ60, Volvo Recharge |
10-22-2024, 06:32 AM | #21 |
![]() ![]() ![]() 539
Rep 651
Wow what an awesome build. And such great info too! Just as excited about the 9k rpm redline as the 1500hp 😝.
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
10-23-2024, 07:07 AM | #22 |
![]() ![]() 4311
Rep 2,081
NASTY! Great job guys!
