      06-29-2008, 10:06 AM   #1
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Adjusting Trunk (Boot) Panel Gaps
My SGM 135i came with a really odd adjutment on the boot lid, the top of the trunk fit below the fender line. (See pix.) - Almost every opening panel on a car will have a means of adjustment and a little visual inspection turned up the adjustment point for the rear deck lid (deck, boot, trunk, can't think of many more ways to call the dam thing ; -)
So here it is:
  • Open the boot
  • Remove the plastic cap over the 8mm screw
  • Raise or lower the screw as needed
  • Replace the cap and test the fit
  • Remove the cap and readjust
  • Repeat until the fit is where you want it to be
Remember, the adjustment will be a compromise between the fit of the decklid at the back light and at the rear of the car.
Complexity 'stars' - none, my dog could do it if she had opposible thumbs. ; -)
      06-29-2008, 11:13 AM   #2
gizmo
Drives: 135i
Thanks, I also have the same issue... Noticed it yesterday while I was giving it a wash.
2008 135i Premium/Sport/Cold CA/HiFi
      06-29-2008, 11:38 AM   #3
hansenc
1addict, and proud
hansenc's Avatar
16
Drives: 128i
2008 128i  [0.00]
Thanks!
I noticed the same thing when washing my 128i I will have to go out and do this.
      06-29-2008, 12:33 PM   #4
Jamze
United Kingdom
Drives: AW 320d Touring
Mine's the same. Deck of boot/trunk is below the line of the C pillar. Perhaps that's how it's supposed to be :smile:
2010 BMW 320d M Sport Business Edition Touring, Alpine White
2006 MX-5 Mk3 2.0i Sport, True Red
2008 BMW 120d M Sport Coupe, Alpine White (gone)
1999 VW Golf Mk3 2.0 Cabriolet, Jazz Blue (gone)
and an Orange P7 mountain bike!
      06-29-2008, 01:05 PM   #5
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
I guess we'll find out when it rains.
      06-29-2008, 01:39 PM   #6
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
I'll let everyone know if it is an issue. : -)
Edit - I checked the seal between the deck lid and the weatherstripping by applying dots of a liquid wax at various points on the weatherstripping and then closing the trunk. The deck lid showed a wax spot at each point it occurred on the weatherstripping. It should be as watertight as before the adjustment. (And that's a DIY check to make sure it is still sealing to the weatherstripping ; -).
      06-29-2008, 02:42 PM   #7
MastaMind
I like beer
32
Drives: AW 135
Thanks for posting this. I washed and waxed my car today and noticed I have the same issue. I'll give this a shot.
      06-29-2008, 11:57 PM   #8
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Hugo,
Have you noticed a similar gap with the hood? Mine has both boot and bonnet offsets.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      06-30-2008, 07:02 AM   #9
atr_hugo
No longer moderate
atr_hugo's Avatar
Drives: '13 135i
Hood's not as bad as the trunk was. I thought my rear deck was correct until I saw Brain's TiAg 135 and his decklid was adjusted correctly from the factory/VDC. Wonder if they have a problem seeing this gap on the darker paint surfaces?
      06-30-2008, 09:43 AM   #10
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
That's a nice little DIY, Hugo! I was looking at that same gap on my SGM but was too lazy to do anything about it. Your comment about your dog doing it has finally shamed me into action.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      07-01-2008, 12:19 PM   #11
Jamze
United Kingdom
Gaps are really obvious on AW, but I've got the same bad-looking adjustment as atr_hugo. Might give it a go - but last time a fiddled with the fit of a boot/trunk lid, it took a chunk of paint off the top of the bumper when I closed it...
      07-01-2008, 05:58 PM   #12
hansenc
1addict, and proud
hansenc's Avatar
16
Drives: 128i
2008 128i  [0.00]
So I started to adjust my trunk lid, one sit went great, backed the screw out and it started to fit better, turned to the other side and backed the screw out and went to shut the trunk. nothing it won't shut. I backed both screws back down and nothing it STILL won't shut.
What could I have done wrong?!?
      07-01-2008, 06:12 PM   #13
hansenc
1addict, and proud
hansenc's Avatar
16
Drives: 128i
2008 128i  [0.00]
Finally got it to shut again by backing them all the way back down. guess I didn't go far enough. guess mine will stay the way it is. I will ask the dealership about it when I go in later this week.
1addicts
