      07-01-2008, 02:19 PM   #1
S54dan
I no longer work for United BMW!
S54dan's Avatar
309
Drives: E46 M3, E46 330i ZHP, E36 325i
1994 BMW 325i  [8.50]
2005 M3  [9.66]
2005 325i  [8.00]
2003 330i ZHP  [9.00]
United BMW - The Wait Is Over! Performance Suspension
The long awaited BMW Performance suspension is finishing it's final details! I have been in contact with BMW almost DAILY on this subject, and I finally am able to offer you the kit!!!! Yes, the springs are Yellow :wink: as portrayed in the catalogs.
I am currently waiting on the kits to come in, however BMW has changed it up a little. There is no longer one part number for both the sport and non sport-package cars. There are now two different kits depending on what options you have on your car. **VERY IMPORTANT** -- WHEN ORDERING, PROVIDE THE LAST 7 DIGITS OF YOUR VIN (VEHICLE IDENTIFICATION NUMBER) IN THE ORDER COMMENTS!
*** Springs are sold separately
Kit includes:
- Rear Sway Bar(Not required for Parts Kit # 33 50 0 444 831)
- Front Sway Bar
- Front McPherson Struts (2)
- Rear Shock Absorbers (2)
- Bottom Spring Supports (4)
- Top Spring Supports (4)
- Front Stabiliser arm rubber bearing (2)
- Rear Stabiliser arm rubber bearing (not required for kit # 33 50 0 444 831)
- Rear auxiliary shock absorber (2)
- Front auxiliary shock absorber (2)
- Supporting bearings lower section
- All fastening pieces
Parts needed to order separately
- Front Sport Springs (2)
- Rear Sport Springs (2)
Feed back can be seen at the following links:
http://www.1addicts.com/forums/showthread.php?t=19119
http://www.1addicts.com/forums/showthread.php?t=20219
http://www.1addicts.com/forums/showthread.php?t=17695
BMW CCA, PCA, & CHIN Motorsports Instructor.
      07-01-2008, 02:44 PM   #2
joelk
joelk's Avatar
Drives: Space Gray E90 M3
ordered. email with VIN sent. keep us posted on the springs. thnx dan.
edit: dan please don't mail mine. i want you guys to do the install. thnx.
e90 M3, Space Gray / Extended Black, ZCP, ZCV, ZP2, DCT
sold: 2008 BS 135i 6MT
      07-01-2008, 02:50 PM   #3
Bullitt
Bullitt's Avatar
91
Drives: 135i
2008 135i  [0.00]
Joelk, please update us on your thoughts after you get them installed! You're so lucky to be near Dan's dealership.
      07-01-2008, 04:49 PM   #4
S54dan
S54dan's Avatar
309
2005 M3  [9.66]
2005 325i  [8.00]
When you order the kit, I'll add the springs in there when you provide your VIN #.
I just updated the spring prices (found out the price just now). You will need to order 2 front, and 2 rear springs along with the kit itself
      07-01-2008, 05:46 PM   #5
rcracer_tx
Drives: BSM 135i
So theres no swaybars included in the kit if you already have the sport package:iono:
      07-01-2008, 07:05 PM   #6
135-CS
Drives: EVO8,EVO9,E90,E82
Dan, those springs will fit our stock 135i suspension? How much would drop the car?
Thanks
      07-01-2008, 07:30 PM   #7
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
Dan, suspension question #1,344,300. How many hours would a dealership charge for the install?
Thanks.
      07-01-2008, 08:54 PM   #8
gizmo
Drives: 135i
Thanks.
11 million!
No offense Dan, your prices rock.
2008 135i Premium/Sport/Cold CA/HiFi
      07-01-2008, 09:57 PM   #9
Call
Call
Call's Avatar
Drives: 08 135i, 08 & 07 X5, 05 MCSC
I have the sport suspension on my 135i. How does this suspension differ from the preformance suspension?
Call
      07-02-2008, 10:38 AM   #10
S54dan
S54dan's Avatar
309
2005 M3  [9.66]
2005 325i  [8.00]
Thanks.
BMW calls for 8 hours, and recommended 2 hours for alighment.
The entire suspension has to be taken apart, so it is definitely a time-consuming job.
Since the ZSP cars already have a different suspension, BMW is not changing the sways, but everything else will change
Originally Posted by gizmo
11 million!
:biggrin:
Call
Lowers the car about .5 - .75 inches. As with any suspension kit, improves handling at the cost of quicker wearing tires
      07-02-2008, 10:45 AM   #11
blackbubblebum
Drives: 06 325i
So how does this differ from stock 135 suspension. Or how much does it lower stock 135?
      07-02-2008, 11:11 AM   #12
135-CS
Sent you a PM!!!
      07-02-2008, 11:58 AM   #13
RobLS
Drives: M3 Coupe
135i-CS, I think he stated how much it would drop the car.
      07-05-2008, 03:01 AM   #14
SF_VR6
Drives: 16' X5 M-Sport / Space Gray
2008 BMW 135i  [0.00]
so what BMW considers a suspension performance upgrade is just shorter springs?
not shock/spring combo upgrade?
no coilover?
Why would one go this route rather than something aftermarket like H&R?
I'm new to all this.
      07-05-2008, 08:45 AM   #15
jlee
jlee's Avatar
Drives: M2CS+GTS Targa+RRS SVR
How do you figure ? his initial post lists parts included in the kit and it sounds pretty comprehensive to me. It actually sounds like its everything BUT the springs.
Jeff
no coilover?
      07-05-2008, 10:39 AM   #16
joelk
joelk's Avatar
Jeff
i think the person was lazy and didn't actually read the thread.
      07-05-2008, 11:11 AM   #17
CDR_UK
Drives: AW 1M
Why is the same price for 135 with sport package - when sways are not included - surely it should be cheaper?
      07-05-2008, 08:37 PM   #18
FibreOptix
FibreOptix's Avatar
Drives: BMW E90 335i
i'm not sure why so long if you are replacing the springs and struts? if you already have your NEW setup put together, whats taking the old setup out as one and putting new back in as one? If there are any pieces you need in the old suspension, just buy new ones (bushings, washers, etc).
      07-05-2008, 09:21 PM   #19
S54dan
S54dan's Avatar
309
2005 M3  [9.66]
2005 325i  [8.00]
The kit is the same as the E46 and E90.. which replaces a lot components of the stock suspension. Just doing Springs on a normal car will take some time ( can be up to a few hours), but the kit involves replacing the stock pieces of the suspension.
      07-05-2008, 09:53 PM   #20
Bullitt
Bullitt's Avatar
91
Drives: 135i
2008 135i  [0.00]
Jeff
I don't see coilovers here either. Maybe I need an education in suspension.
      07-06-2008, 01:00 PM   #21
smcgt
smcgt's Avatar
Drives: 2008 Monaco/Savannah BMW 135i
Ok, what are "auxillary shock absorbers" ? Does anyone have an exploded diagram of the suspension or parts diagram?
      07-06-2008, 06:28 PM   #22
rcracer_tx
Drives: BSM 135i
Exactly what i was thinking...WTF are those....
1addicts
