BMW M2 Forums 2023+ (G87) Exterior Modifications
      12-08-2024, 06:36 PM   #1
ajchoi
Drives: 2024 ZB M2 6MT
ZB M2 CF installed part pics
Hi all!
I installed the following and figured I’d share how it looks in case people were curious. All of these I DIYed and will describe how difficult or easy each was as well as my total price for each:
  1. Autotecknic OEM-Style CF Mirror Caps: $375 total on a holiday discount
  2. BMW M-Performance CF Spoiler for G87/G42: $515 total on holiday discount
  3. BMW M-Performance G87 CF Diffuser: $1078 total
I don’t regret splurging for either M-Performance part at all FWIW.
The mirror caps took me the longest time to figure out a good solution. I ended up using a wide plastic pry tool wrapped in a microfiber cloth to pry the bottom of each mirror while the mirror was pointed as upward as possible. A bit of pressure and it pops off but is still connected by a wire. That gives your hand access to the clips holding most of the mirror cap in. Find a video that does that version of the mirror cap install process instead of the one that tells you to try to do it without popping off the mirrors. I had to troubleshoot one and did the process 5x on the driver side with no problems and made my life easy.
The spoiler was surprisingly easy. I thought it’d take me 4-6 hours based on videos I watched but with my tools it took me 2 hours start to finish. I used a cheap but decent heat gun to heat up the original spoiler and adhesive and spent a good amount of time making sure at least half of it was warm enough. Then I took a plastic pry tool with a flat angled side and pried off the edge of the spoiler. Put fishing line in there and sawed away. Repeated as needed then used a 3M eraser wheel attached to a drill to get rid of the remaining residue. Cleaned up with goo gone, then detailer cleaning spray, then alcohol wipes. Put 3M 5952 VHB 2 sided tape on the M-Performance spoiler and voila! 2 hours.
The M-Performance diffuser is the easiest. It’s all plastic clips. The tough ones are the ones on the bottom between the exhausts. You need a plastic pry tool with a slim and flat tip similar to a flat head screwdriver to easily get those types of clips unseated. But a little review of how the clips work if you look and you’ll see what I mean.
Pics for all the end results below!!
Size:  155.2 KBName:  F7F9928B-B486-4680-A8CE-4F13A0D69F47.jpeg
Size:  244.6 KBName:  7574750A-ED6E-4E74-BDCC-3EA0200321DD.jpeg
Size:  295.6 KBName:  6B550692-B8C3-4CA4-BCC3-0CDEB6286ED3.jpeg
Size:  316.5 KBName:  8F4847B7-045F-4E32-A05B-EEF60621A9DF.jpeg
Size:  346.6 KBName:  E513D8EF-5E49-418D-A08E-6F630D0FD5DF.jpeg
Ronin761689.50
DrewNewM21151.50
Mega8489261.00
M2Va55.00
M27175.00
jas1651610.00
      12-09-2024, 10:36 AM   #2
Ronin76
Ronin76's Avatar
Drives: 2018 Tesla Model 3
Originally Posted by ajchoi View Post
Hi all!
The spoiler was surprisingly easy. I thought it’d take me 4-6 hours based on videos I watched but with my tools it took me 2 hours start to finish. I used a cheap but decent heat gun to heat up the original spoiler and adhesive and spent a good amount of time making sure at least half of it was warm enough. Then I took a plastic pry tool with a flat angled side and pried off the edge of the spoiler. Put fishing line in there and sawed away. [...]
Good work. The first pic without the spoiler makes the car look naked lol. This car def needs a spoiler…at least from that angle.
ajchoi321.50
      12-09-2024, 12:42 PM   #3
ajchoi
Thanks! And totally agreed, the back of this car looks so different, especially from a profile view where the bumper stuck out so much further than the trunk without a bigger spoiler there.
      12-10-2024, 11:38 PM   #4
Mega8489
Mega8489's Avatar
261
Drives: Bmw 2025 m2 in order
Hi all!
Attachment 3617813Attachment 3617814Attachment 3617815Attachment 3617816Attachment 3617817Attachment 3617818
I bought a lot of their products for the m2 during the holiday sale, im still waiting for them, but how’s the fitment on the mirror caps ?
Thank you.
      12-11-2024, 10:08 AM   #5
ajchoi
Thank you.
I had a problem with the drivers side mirror cap fitment and no matter what I did it didn’t fit correctly below the lighting piece. I attached a pic below to show what I mean. I’m pretty OCD so this stuff bothers me and I probably lost sleep thinking about it. So here’s the good news: their customer service is great. I sent a dozen pictures and described attempting to reinstall it 4-5 times to ensure it was a defect and they’re now in the process of mailing me a new one after they test it out on a G8X before mailing. And I don’t have to ship the defective one back! Happy with this outcome so long as I get the corrected piece soon.
Ronin761689.50
      12-13-2024, 09:26 AM   #6
Ronin76
Ronin76's Avatar
Attachment 3619606
I have purchased several CF exterior bits...except the mirror caps because of this. I just know me, being inexperienced, would somehow did it wrong, break something, or it not fit right and it would drive me mad.
      12-13-2024, 11:15 AM   #7
nicoG87
Drives: BMW G87 M2
Attachment 3619606
wonder if they sent you a RHD piece by mistake.
      12-13-2024, 01:15 PM   #8
ajchoi
If the replacement still doesn't fit right I'm honestly just going to save up and spend the stupid amount on the actual OEM CF ones because I'm in the same boat as you with wanting it perfect haha.
That said, the install process itself was easier than I thought it was going to be once I figured out how to pop the mirror off its mount to get to the clips behind it.
I was kind of thinking the same. At least with the replacement they confirmed they're fitting it to a LHD G8X car to validate it fits (and their HQ is in California so I expect they'll have the right model there lol)
      12-13-2024, 08:02 PM   #9
ajchoi
Update on mirror cap: they said the batch was actually defective so I’ll be getting a new one from a new batch in early January
      12-30-2024, 11:30 AM   #10
ajchoi
Update: I bought the gold/bronze 1000M wheel tire package because I like the look and this allows me to easily use my stock wheels and tires at the track someday. I went with it because the overall cost of the 1000Ms with Yoko Advans, TPMS, mount/balance would generally be the less or same as other setups and I can just bolt these on with no other work! Will share more pics once I get them delivered and installed.
After this I’m done for a while. The last CF bits I want aren’t things I’m willing to install myself (Amarid antenna cover and CF front air inlets), though I may go for the Autotecknic CF front lower center piece with the IND color matched bottom portion.
      12-31-2024, 12:06 AM   #11
SpaceGhost
Drives: 2024 740i xdrive
Please let us know how the new batch fits.
      12-31-2024, 03:48 PM   #12
ajchoi
Will do! So far it seems like they’re gonna get this resolved sometime in January but I’ll def keep this thread updated once I get an update from them.
      12-31-2024, 04:18 PM   #13
SpaceGhost
Thanks!
      01-12-2025, 02:13 AM   #14
ajchoi
Still waiting on update about the mirror cap but threw on some 1000M wheels in the meantime
jmg20079.50
WWM31228.50
      01-12-2025, 09:39 PM   #15
CFO
Drives: 2021 BMW M2C HS DCT Sunroof
Any difference in ride quality with the bigger tire/wheel set up vs original stock?
      01-12-2025, 11:24 PM   #16
ajchoi
Haven’t driven it enough to really notice much but it seems relatively the same as the original to me so far. I’ve read posts on here saying slightly worse ride quality and I imagine that’s probably true
