07-30-2008, 12:23 PM | #1 |
Rep 536
Let's Install the New Style Wheel Logo Roundels
BMW has a new style wheel logo Roundel. The new style is cleaner and a better fit than the old style logos.
Old vs. New: To install the new center caps, you can either remove the wheels and push the caps out from the back, or you can use the suction cup method. If you have the wheels off, it is a good time to switch the Roundels out, but if you do not have the wheels off, it is a lot of work for a simple mod. I used the suction cup method. 2 Hook Style Suction Cups ($1.99 from Target): Apply the suction cup to the stock Roundel: Then pull straight out: Then install the new Roundel (the wheels even appear to have changed :wink If you use this DIY, please post a thank you. |
07-30-2008, 05:48 PM | #5 |
Rep 16
Andy,
Where can we get these? You selling them?
2014 X3 28i xDrive - Jet Black, Black Leather, Cold Weather, Driver Assistance (On order) 2017 M240i - Mineral Grey, Terra Leather, Cold Weather, Driver Assistance, Nav, 6MT |
07-30-2008, 08:46 PM | #7 |
Rep 3,323
If these will be for 09's and up then we would be removing one of the unique trademarks of the Y 1 of the 1.
That said I want the new roundels. They look better. :biggrin: |
08-10-2008, 01:43 AM | #10 |
NRA Life Member, BMW CCA 30 year member
181
Rep 2,614
Performed Andy's DIY earlier this evening, a simple prying device assisted in making the magic sucker-thing happen. I submit a modified tongue depressor, reduce the edge thickness so as to resemble a blade, pull the sucker, insert the tongue depressor into the gap thus created, boink, roundel out. The first roundel took 10 minutes, which, included brain-farting the idea, modifying the tongue depressor, doing the deed, the last roundel extraction/install took 20 seconds. It works. The 'tool' got a bit banged-up...
Thanks Andy.
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
08-10-2008, 03:19 AM | #12 |
Rep 1,058
Why not just remove each wheel and push the centre cap out from behind? While your there you can give the whole alloy a good clean. Something you can never do properly with the wheel on.
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
08-10-2008, 06:01 AM | #13 | |
Rep 4,093
(just a thought though the 1 er doesn't come with a jack does it.... priceless!) |
08-10-2008, 08:49 AM | #14 |
Rep 536
08-10-2008, 09:13 AM | #15 |
Call
21
Rep 683
I just used a small prying pick to remove the oem's which were a little loose anyway. I couldn't believe how much better the new roundels looked. Sometimes it's the little things that can make all the difference.
Call
08-10-2008, 09:17 AM | #16 | |
Rep 5,970
Because here in the states we don't get average 6 weeks of holiday time every year. The half day it takes to do it your way is better spent :drinking: |
08-10-2008, 09:21 AM | #17 |
Rep 10,176
<< Is guilty of removing wheels to wash from the back side. It works soooo much better and more thoroughly than cutting up your knuckles on the brake shield, reaching through the spokes, on a much less thorough cleaning job.
Btw, I love how those roundels do dress up my wheels too. |
08-10-2008, 07:51 PM | #18 |
Good life
130
Rep 1,937
Please post before and after pics of the 1er wheels. Also +1 on availability of cf caps.
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
08-10-2008, 08:26 PM | #19 |
Uber-Lee7 Member
47
Rep 1,440
awsome, didn't even know there was a new wheel roundel...
a new DIY is never a bad thing!
08-11-2008, 12:53 AM | #20 |
181
Rep 2,614
Before...apologies for the filthy rims, I blame 'the mountain', see sig.:wink:
08-11-2008, 12:53 AM | #21 |
181
Rep 2,614
After...the replacement roundels retain their position far better than the stock items as well.
08-11-2008, 11:24 PM | #22 | |
Rep 216
Here is one of many vendors selling the E-Z Detail Brush. http://www.autogeek.net/ezdebrfca.html It is well worth the money. |
