08-24-2008, 08:28 PM | #1 |
Rep 2,203
jack point inserts?
so my jack points are plastic hollowed out squares that look like they accept an insert for a jack
am I missing something? should I have inserts for them? I need to install mudflaps but got stuck when I tried to figure out how to jack the car up |
08-26-2008, 07:33 AM | #5 |
Rep 2,203
anyone know what brand/model jack is low enough and long enough to reach that front center lift point?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
08-26-2008, 10:10 AM | #7 |
Rep 10,176
I have a hockey puck that I cut up on my bandsaw to fit the jacking point recepticle.
I know there was somebody on e90post was selling billet aluminum pads that they made up to fit on most floor jack heads and they have a piece the goes into the indent. |
08-26-2008, 01:21 PM | #8 |
Rep 295
These guys made some aluminum billet jack points for the MINI that are also shorter than stock for better jack clearance. Maybe those would work with the 1 also or they could make some up. THey are a little pricey IMO, but they do seem to work well from what I have read online.
http://www.txwerks.com/servlet/Categories?category=MINI%3AJack+Points |
08-27-2008, 08:39 AM | #10 | |
Rep 295
Keep in mind that the piece you linked is an adaptor that will fit into the jack points and the cup of a floor jack (and is actually quite cool btw). The others are actually replacement jack points that are shorter than the stock ones. |
10-21-2008, 08:49 PM | #13 |
Rep 1,118
Drive up on 2X4's then you can hit the center jackpoint no problem with a decent pulley jack...
Then throw some stands up front on the 2 jack pts.. then lift from the back center jack point straight up and slide to more jack stands under the back 2 jack points... This is what I did to get all 4 tires off at once!
-----LS3 C6----- z51 suspension, NPP dual mode exhaust(wild2mild),20% tint, zr1 replica wheels, gloss black fender stripes R.I.P SGM 135i w/ some mods |
10-22-2008, 12:45 AM | #14 | |
Rep 356
10-22-2008, 01:56 PM | #15 |
Rep 1,101
Anyone tried these? I saw them on the website when I checked out the jack point inserts. I am debating getting a torque wrench to do up my lug nuts or a set of these.
Ever tightening your wheel & wonder if you have it torqued to the right settings? These Schwaben torque sockets take the guess work right out of the equation. Just tighten away & Schwaben torque socket will ratchet when the appropiate torque has been reached. Come withs 17mm 19mm & 21mm 1/2" impact sockets. Kit comes in nice compact plastic blow case. Preset for 100Nm 74ft-lbs |
10-22-2008, 03:02 PM | #16 | |
Rep 564
10-28-2008, 01:16 PM | #17 | ||
Rep 356
"Thank you for the inquiry, unfortunately those jack pads only work on the new E90 chassis." |
10-28-2008, 01:21 PM | #18 |
Rep 2,203
whoever emailed you was wrong, they work great on my 135i
10-31-2008, 10:34 PM | #21 |
Rep 128
I made two of these at work to fit on a low profile aluminum jack. A little different than the ECS version, I made the pad larger diameter and made it cupped to fit the jack pad.
[SIGPIC][/SIGPIC] |
