08-28-2008, 12:26 AM | #1 |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
Recirculation Valves For The BMW N54 twin turbo motor 135 335 535 models
Some of you may know them as Blow off valves or BV, but since these do not blow off to the atmosphere, they are diverter or recirculation valves or DV's for short.
"Developed specifically for BMW’s all-new N54 twin turbo motor, as found in the BMW 135,335 and 535 models, Forge Motorsport adds another replacement valve application to our already extensive vehicle specific and universal valve lineup. While virtually identical in operation to the Bosch style valves as used from the factory on many other turbocharged applications, primarily Volkswagen and Audi, BMW has utilized a very different type of valve connection mechanism that makes their product and our replacement components very unique. Starting with the world’s best selling direct replacement Bosch style valve, our own 007P piston-based design, we have revised virtually every single component of the valve body, (except the internal piston), in order to retain BMW’s unique connection mechanism yet offer improved functionality in every other possible way. The entire valve assembly is precision CNC machined from T6-6061 billet aluminum alloy on our very own Mazak CNC milling machines. Again, the valve is an aluminum piston based design, offering significantly improved reliability over the failure prone OEM diaphragm valves, yet with no change to valve response time. We utilize ultra high temperature Viton brand silicone o-rings for sealing and Mobil1 fully synthetic bearing grease for lubrication. The valves are fully tunable for both boost holding capacity and response by way of proprietary interchangeable springs and shims (washers to marginally adjust preload). By utilizing this method of valve tuning with multiple custom spring rates, the valves will retain the maximum range of piston travel and flow volume regardless of which spring rate is used. Valves with a singular spring requiring that adjustments be made by continually adding preload will suffer from decreased piston or diaphragm travel as the spring tension is increased. Though these types of valves may hold high boost levels under load, they will actually suffer from limited flow volume at throttle lift when the valve vents. The hoses included in the kit are a custom made multi-layer fabric reinforced flexible silicone hose that are designed to allow compatibility with the stock airbox and charge piping setup without any permanent modification being required to adapt our replacement valves. Even the included hose clamps are overkill. They are specifically designed for use with silicone hoses, utilizing a beveled band edge and a pressed in drive mechanism rather than perforated. They are even approved by NATO for international military use. All told, this direct replacement valve kit will be suitable for a bone stock car to one that is heavily modified. They can be installed on the car right on the showroom floor and they will last well past having upgraded your intake, exhaust, and ECU software. They are capable of handling an infinitely wider range of boost pressure, more reliably, than the OEM valves, and they carry an unlimited lifetime warranty and money back guarantee." Above information was quoted from Forge Motorsport. These are very easy to install and retains the stock intake piping, which is fine by design, flows very well, and less likely to retain heat! Price is $250.00 with FREE shipping to the 48 States! Kits are in stock and ready to ship, but they are going fast |
09-05-2008, 09:07 AM | #2 |
3886
Rep 54,510
Drives: F80 M3
These are in stock and ready to ship!
If you are local, we will install these for free! |
10-03-2008, 01:32 AM | #4 |
3886
Rep 54,510
Drives: F80 M3
Read what Forge Motorsport had to say about knockoff Diverter Valves and replacing the discharge tube with knobckoff DV's!
We were right all along, the discharge tube isn't a restriction! Why would you use a metal tube there to further heat soak the engine anyway! "To be perfectly honest, I have no problems calling this a cheap knockoff in every way. First and foremost, they are buying out of China, copies of our original style 007P diverter valves that we sell to the VW and Audi community. http://www.forgemotorsport.com/uploa...s/FMCL007P.jpg You can find knockoffs everywhere: http://www.freedomdesign.com/Merchan...ory_Code=golf4 We have since redesigned the exterior of the valve to differentiate our original design. http://www.forgemotorsport.com/image...s/FMCL007P.jpg They copied our swivel cap version too: http://www.freedomdesign.com/Merchan...ory_Code=golf4 http://www.forgemotorsport.com/conte...duct=FMCL007PA As another point in a long list of examples, these same people copied our short shifter for the VW applications as well. http://www.freedomdesign.com/Merchan...ory_Code=golf5 http://www.forgemotorsport.com/conte...product=FMVWQS Additionally, replacing the intercooler pipe is completely pointless as the OEM pipe does not pose a restriction in flow, and is only being done to facilitate the attachment of knockoff valves with universal hose connections rather than the application specific clip connectors that we designed for our valves. So basically, they are charging more money for an inferior knockoff product that will perform absolutely no differently due to the pipe. I shudder at the thought of BMW owners condoning and endorsing the counterfeit industry, but it is what it is." |
10-13-2008, 10:19 AM | #7 | |
Rep 750
10-22-2008, 09:25 AM | #8 |
3886
Rep 54,510
Drives: F80 M3
11-14-2008, 12:20 AM | #11 |
Rep 4,822
I have a set sitting on my desk right now. What a beautiful work of art! I used Forge Motorsport DV in my Audis/VWs and have never had a problem even with very high boost. Can't wait to get it in my car!
11-17-2008, 10:26 PM | #12 |
3886
Rep 54,510
Drives: F80 M3
