View Poll Results: Which way of installation is better 3M or betalink adhesive | |||
3M | 13 | 48.15% | |
Betalink adhesive | 14 | 51.85% | |
Voters: 27. You may not vote on this poll |
09-01-2008, 11:19 PM | #1 |
Rep 182
performance spoiler owners which way better? (3M) or (betalink adhesive)
Hi there guys i just order the performance spoiler, but now i'm wondering which way of installing it would be better? what do u owners think? using the 3M or the betalink adhesive? which way is better?
09-02-2008, 01:13 AM | #3 |
Rep 226
I went betalink, and it works well - straightforward if you follow the install advice on this forum.
Can't comment on 3M, but I guess that BM proposes betalink for a reason... |
09-02-2008, 04:05 AM | #6 |
Rep 182
betalink adhesive is a glue like stuff...that sticks yr spolier onto yr car.....ok seems like everyone's going fot betalink adhesive for now....which is wt i'm thinking also...but the only thing is can i still uninstall it inthe future? and if i F up and get some of the on somewhere ells of the car can i remove them?
09-02-2008, 04:32 AM | #7 |
Rep 58
I used the Betalink, it worked great.
My Lemans blue beauty with black leather.
http://www.garaget.org/?car=101344 |
09-02-2008, 07:50 AM | #8 |
Rep 206
the black stuff
I ended up using the goop that Dan sent with the CF spoiler from United BMW. I followed the directions and took my time. My 13 year old daughter helped and it was easy. I taped everything up with blue painters tape before strating and that made clean-up quick and easy. My spoiler is SOILD and feels like its bolted to the car.
09-02-2008, 09:26 AM | #9 |
Cruising Daily
11
Rep 209
I used Betalink. Easy to use and apply. just follow the directions, lets of prep and use the cleaner provided it works good.
2008 BMW 135i - AR Catless DP - Agency Power Mids - Corsa Exhaust - KW v2 - Performance Side Skirts, Pedals, Steering Wheel, SSK. - CF Spoiler, Diffuser, Mirror Caps - Injen Intake - JB3 2.0 - CPE BOV Kit (HKS) - 6k HID AE - 6700k D1S - Evolution Racewerks FMIC -
09-02-2008, 10:37 AM | #10 |
Call
21
Rep 683
I used the 3M but cut it into small enough sections to cover underneath completely where the spoiler contacts the boot.
The installation is solid and very firm...no issues. Call
09-02-2008, 09:28 PM | #13 |
Rep 932
+1 on Betalink. The 3M is just a tad to thick, while it does the trick, it doesn't allow the spoiler to sit as flush, leaving slight gaps, especially noticeable on the ends.
Just my .02 cents. Fran |
09-06-2008, 08:47 PM | #17 |
ilmostro
Rep 171
The Betalink is available from the parts department at your BMW dealer. To answer the question of is it able to be removed...No, it is not able to be removed. It is an epoxy. It chemically breaks down and then bonds the materials. I have used this product one 2 occasions and as far as I can tell, it will not break it's grip.
Hope this helps. |
