09-11-2008, 07:11 PM | #1 |
Rep 2,650
Riss Racing Full Stage 3 Intake (videos/pics/info)
The N54 motor has a very unique design. Just like the RB26DETT (Skyline), it has a parallel twin turbo set-up. Basically what this means is that each turbo is driven by half of the engines spent exhaust energy. You can see this when looking at the exhaust manifold on the N54:
See how each turbo has a separate manifold from 3 of the 6 cylinders. This means that one turbo cannot work harder than the other – they both must do their job equally. This is very important to consider when designing an intake system since efficiency is determined by the weakest link. In other words, if one turbo is getting more air than the other, the engine must regulate to match the turbo getting less air so they are working together. Not only is the efficiency of the turbos dependent on the amount of air, but also the density of the air. The amount of power transferred to a turbine is directly proportional to the size of the turbine blades, to the DENSITY of the air, and the cube of the air intake volume. This is why BMW uses a single plenum design on the N54. Each turbo is able to get the same air density and air volume enabling the motor to run efficient. Of course there is always room for improvement. Riss Racing has created the first and only Ram Air Plenum Design Intake on the market for the N54. The intake was designed with one thing in mind…power. Of course there are the additional bonuses of hearing your twin turbos breathe freely with no restrictions from the intake side. The intake utilizes a large K&N oval shaped filter that pulls more than enough air into the center 3” plenum. From the center plenum, both turbos get THE SAME air density and a dramatic increase of air volume which promises for much better throttle response and overall performance. FULL STAGE 3 FINAL PRODUCTION RISS RACING INTAKE SYSTEM INSTALLED! Riss Racing Intake Stage 1 Installed on 135i Riss Racing Intake with PS bracket, and K&N filter. Huge K&N filter with great surface area. Riss Racing 135i Stage 1 Intake video. [u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/tQiYg9GL8uk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/tQiYg9GL8uk&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b] ORDER price $319 - http://www.rissracing.com/ramintake.html Riss Racing 135i Stage 2 - Intake / Air Scoops & Shield. Stage 2 will include this unit & scoops. Instead of just a shield working with the OEM snorkel. We went one step further and made and entire NEW snorkel system that directs air perfectly over the massive K&N filter. With the HUGE increase in plenum size of the new snorkel system. We now can really maximize the air brought in from the Riss Racing scoops. This new snorkel is close to double the flow capacity of the OEM system. :headbang: Installed on the car.... Installed with grills off.... SHIELD + PICS of scoops uninstalled will be ready this week. :thumbup: Riss Racing 135i Stage 3 - Intake / Air Scoops & Shield / Hard pipe & Diverter Valves. Diverter valves & Hard pipe High grade T-Bolt clamps Adjustable springs. Riss Racing 135i Diverter valve video. [u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/1SoI9bIYdcA&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/1SoI9bIYdcA&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b] Last edited by Riss Racing; 02-12-2009 at 06:30 PM.. |
09-11-2008, 07:25 PM | #2 |
1Addict, and proud
163
Rep 1,436
Drives: 2009 AW 135i M-Sport
OMG! THE INTAKE SOUNDS TRULY AMAZING! =)
SOON ILL ORDER MINE!
BMW AW 135i ZMP:6mt,Coral Red Leather,Silver Matte Trim,Heated Front Seats,I-Drive,HD Radio,Ipod/Usb,Comf.Acces www.wix.com/TT135i/Moi |
09-11-2008, 07:31 PM | #3 |
Rep 4,070
Just waiting to see the full setup(scoops and such) w/Dyno so I can make my final decision...
09-11-2008, 07:36 PM | #4 |
Rep 2,650
09-11-2008, 07:36 PM | #5 |
Rep 2,650
09-11-2008, 09:35 PM | #8 |
Rep 2,650
It will be up on our site soon.
For now it is on www.ind-distribution.com www.jlevisw.com www.wheelsto.com |
09-11-2008, 11:00 PM | #12 |
Rep 4,311
Drives: Supercharged E90 M3
Thats Awesome!
Nice design, and sound.
09-11-2008, 11:13 PM | #14 |
1Addict, and proud
163
Rep 1,436
Does th 1 on the intake video have only the Intake or is the RR pipes and exhaust on it in the video as well? No videos of the intake and DDV together on a driveby yet?
09-12-2008, 07:41 AM | #15 |
Rep 1,015
BUMP for picture rehost due to work filters
Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.” |
09-12-2008, 08:27 AM | #16 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
+1^^^^
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
09-12-2008, 08:43 AM | #17 |
Rep 2,650
Pics direct links.....
Stage 1 intake http://i260.photobucket.com/albums/i...g/DSC00641.jpg http://i260.photobucket.com/albums/i...g/DSC00653.jpg http://i260.photobucket.com/albums/i...g/DSC00619.jpg Stage 3 DDV + Hard pipe... http://i260.photobucket.com/albums/i...g/DSC00453.jpg http://i260.photobucket.com/albums/i...g/DSC00450.jpg http://i260.photobucket.com/albums/i...g/DSC00467.jpg |
09-12-2008, 09:21 AM | #18 |
Rep 1,015
we block photobucket .. if you want .. email me at kraventh1@tx.rr.com and I'll host them for you and put them up here .. thanks, Crowley
09-12-2008, 10:06 AM | #19 | |
Rep 2,650
09-12-2008, 10:09 AM | #20 |
Rep 1,159
On the DV, there are 3 springs options, what are the differences? is it just to adjust how it sound? and not related to performance?
Great Job on the intake! I think that's the biggest K&N filter I've ever seen :w00t: |
09-12-2008, 10:33 AM | #21 |
Rep 1,015
Thanks Crowley
09-12-2008, 11:02 AM | #22 | |
Rep 1,015
can't wait for this .... Crowley
